VideoHelp.com Forum
  1. Hi
    I just converted 2 avi files into mpg2 dvd compliant files
    Now i merged them into 1 big file using tmpgenc using the mpg tools .
    When i try to play it with windows media player it play well in the first part but if i try to scroll to the end on the movie it always freeze and wont play.
    Can anyone tell me how can i solve this problem
    is it in the merge process or in the converting process ?
    btw the 2 sperate mpg files are playing properly.
    Thanx a lot
    tmpgenc mpg tools is not that good for mpeg2 editing. I would use videoredo,mpeg-vcr,tmpgenc mpeg editor or a free tool like cuttermaran,mpg2cut2.
    or join the mpeg2s when you author to a dvd.
  3. Thanx for these suggestion
    what would be your best choice in all these software ?
  4. Member ZippyP.'s Avatar
    Like Baldrick suggested...If you are making a DVD, then instead of combining the the two mpegs they can be "merged" during the authoring process so thay they play one after the other. Far less hassle and less chance of sync problems. Try TDA.
  1. Merging multiple parts of one mp4 file into one file
    By vaultedskies in forum Newbie / General discussions
    Last Post: 16th Nov 2011, 09:08
  2. Merging multiple files as one video file?
    By mikehende in forum Newbie / General discussions
    Last Post: 10th Nov 2011, 06:28
  3. Merging audio file and video file using ffmpeg
    By suresh3484 in forum ffmpegX general discussion
    Last Post: 17th Aug 2008, 21:20
  4. Merging audio file and video file using ffmpeg
    By suresh3484 in forum ffmpegX bugs and suggestions
    Last Post: 27th May 2008, 03:05
  5. Replies: 3
    Last Post: 27th Jun 2007, 10:08
