  1. hello.
    my friend got this karaokes dvds, but my machine is old and only takes vcds, is there a way to convert those dvd to vcds to play in my karaoke machine ?
    thanks.
  2. Hi!
    There should be no problem with converting those DVD to VCD. I'm not sure if the text is a subtitle on the kareoke DVD or if it's encoded within the video stream. If it's as a separate subtitle you have to encode the subtitle with the video if you are making a VCD as VCD doesn't support subtitles.
    However if the text is within the video, then you can simply convert the DVD to a VCD. There's a lot of guides for that here at Videohelp. Check them out.
    // Znooky
  3. Member Cornucopia's Avatar
    Audio may be a little tricky:
    DVD audio may be simple 2 stream switchable, or could be VCD-style [L vs. R] channel switchable, or could be true "Karaoke-mode" DVD which is similar to normal 5.1 audio, but each channel is mixed live together (in ways decided by the user) to form the composite sound (e.g.: Vocal Guide + Harmony + Background Music (stereo)).
    Depending on which type, there will be different methods to extract/combine/recode.
  4. the dvd seems to have 2 different audio. lpcm and ac3. now the question is how do I convert this to vcd and keep the chapters ?
  5. Member Cornucopia's Avatar
    Rip DVD with DVD Decrypter & Demux streams.
    You've got:
    MPEG2 video, as M2V
    LPCM audio, as WAV
    AC3 audio, as AC3
    Chapter log, as ?TXT?
    Convert Video:
    Many usual ways here...ex: D2V-->TMPGEnc-->M1V file
    Make sure you create I-frames at the frames listed in the Chapter Log.
    Convert Audio:
    Open WAV in CoolEdit (or similar), mix to mono WAV. Save as "***_L.WAV"
    Open AC3 in BeSweet, convert to PCM/WAV. Then do the same as LPCM WAV above, but save as "***_R.WAV"
    Open both in CoolEdit (multitrack mode) and mix down to new Stereo WAV.
    Convert to MP2 in TMPGEnc (224kbps, Dual Mono, 44100Hz)
    Mux using TMPGEnc tools to create MPG
    Make VCD in VCDEasy, using Chapter log to create chapters.
    Done!
  6. wow ! seems like a lot of work.
    but Im on it.
    thanks man ! u rock
  1. How to make VCD karaoke from DVD karaoke.
    By johncc35 in forum User guides
    Last Post: 13th Dec 2006, 13:27
  2. Make VCD karaoke from DVD karaoke!
    By DOCHUA1 in forum Newbie / General discussions
    Last Post: 11th Sep 2004, 00:18
  3. How to convert CD+G Karaoke to VCD or DVD Karaoke
    By usernamehere in forum Video Conversion
    Last Post: 3rd Oct 2003, 18:21
  4. DVD karaoke to VCD karaoke with on/off singer voice
    By lyvandu in forum DVD Ripping
    Last Post: 14th Apr 2003, 04:23
  5. Making Karaoke VCD from Karaoke DVD
    By nguyen in forum Video Conversion
    Last Post: 29th Dec 2001, 05:35
About   Advertise   Forum   RSS Feeds   Statistics   Tools
