[I'm using Adobe Premiere 6.5]
I have edited a video, and by editing i mean cutting and pasting different parts of the original video into a new video.
I also cropped the video frame size, [project -> settings viewer -> export settings -> special processing -> modify]
I then attempt to export my video through [file -> export timeline -> movie]
When it is done and when i watch the video, the video is cropped, but the quality is really REALLY bad.
However, when i go to [file -> export timeline -> adobe mpg convertor] and export as a VCD. the quality is exactly the same as the original matieral i worked with, but the video is not cropped.
Could someone please tell me how to export my video CROPPED, but maintain the quality?
What settings do you use when you export the cropped version ?
What were the specs of the original source materials ?
What do you want to get out of this - DVD, VCD ?
Why are you cropping?
And when you enlarge video material, you often cannot maintain quality. That's why you should not crop.
As above, what is the source material?Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Depending on your source footage, simply add a tad bit of gaussian blur (.5 - .7) and you will be able to eliminate the grains.
My experience exactly!Depending on your source footage, simply add a tad bit of gaussian blur (.5 - .7) and you will be able to eliminate the grains
Who cares about detail ? right ?
I care about the quality.
It is not a dvd/vcd, i just merely tested to export it as a vcd.
I just want it as a normal file (avi or mpg) and just run it on my pc.
I have no intention of putting it onto a dvd/vcd disc.
The settings are here.
Sorry about the quality, i wanted to be in mind of people on a slower connection.
I am cropping the original video frame size to a smaller size because there is a logo at the top.
So i am NOT increasing the original frame size, im decreasing it.
How to maintain quality with avidemux? (which video codec?)
By tlee in forum Video ConversionReplies: 7Last Post: 7th Nov 2010, 07:39 -
will crop and resize lose too much video quality?
By kopmjj in forum RestorationReplies: 5Last Post: 15th Jun 2010, 11:48 -
Can't compress and maintain quality. Why not?
By justaguy23 in forum Video ConversionReplies: 7Last Post: 10th Jun 2010, 01:55 -
Best format to use to maintain video quality?
By Blackhawk1 in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 11th Mar 2010, 23:19 -
maintain quality output file after cutting video
By karebo in forum EditingReplies: 14Last Post: 24th Feb 2008, 05:47
