When I capture a still shot from a video clip, the resulting .bmp file looks squashed down. This makes everyone look shorter and fatter. (as if any of us need that) Is this a resolution issue?
44E
Sounds like you are only getting one field of the clip, so you only see every second line. This appears like the image is compressed. See if there is an option to grab a frame, instead of a field. You may find when you do this that any frame grabbed during movement will have jagged edges throughout though.
When you capture a still from video you may need to deinterlace, and change the size of the photo to make it look correct. Search the forum for "capture still from video", and you will find all the necessary information. That is where I found it when I had to do this a few months ago. I just didn't keep the information handy.
Rob
I can only find one setting in reference to capturing still shots. The "Image capture deinterlaced" box is checked.
Does anything else come to mind? Today is the last day of my 30 day trial.
Thanks.44E
Freeware to capture a shot from a video or DVD?
By gastrof in forum Newbie / General discussionsReplies: 7Last Post: 22nd Jul 2011, 03:11 -
How To capture video shot in both sp and lp on the same dvc
By ishwinderjauhar in forum CapturingReplies: 0Last Post: 13th Jul 2011, 08:40 -
Corel Video Studio Pro x4 jumps when capturing?
By TheKillerQueen in forum CapturingReplies: 3Last Post: 17th Apr 2011, 10:01 -
Capturing video through Vegas Movie Studio 9
By Michael Rodriguez in forum CapturingReplies: 1Last Post: 20th Mar 2010, 16:33 -
automatic shot by shot video cutter
By monks19 in forum EditingReplies: 4Last Post: 26th Oct 2009, 19:17
Statistics
Newest guides
Latest tool updates
New media comments
