VideoHelp.com Forum
  1. Is there any program that can somehow restore the quality of old VHS videos to great or near master quality?
  2. Member b1tchm4gn3t's Avatar
    Hollywood has that program I think
    If at first you don't succeed; call it version 1.0
  3. Mod Neophyte Super Moderator redwudz's Avatar
    Simple answer, no. You can never get back what is already lost.
    However you can filter and make it look better than the raw capture. If you capture to AVI, Virtualdub has a lot of filters to clean up a video and make it look better. Or if you have a DV camera with passthrough, VD can accept DV video. (With a DV codec installed.)
    There are other editors that can do it also, but VD is free and has many, many filters. It's a good place to start.
    Lots of expensive hardware usually owned by TV stations will help to a degree, but it depends on the quality of the original. VHS is such a low quality medium to begin with, you will never get master quality from it, no matter what kit you have available.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  5. Just what kind of VHS videos do you have. What is it's
    origeon and explain (demo some pics) of a few frames for
    us to see.
    -vhelp 3601
    VHELP's - Sample Clips [last: 12.29.06],
    my YouTube videos
  6. Hardware works best, every bit helps right down to the cables you are using. Try the restoration forum for more info . I'd suggest starting with a good VCR, that can make a world of difference.
    Software works to some degree but it's been my experience that most filters remove detail just as much as they remove noise. As mentioned above you can't restore what's not there.
  7. Member slacker's Avatar
    The $6,000,000 question is what are you going to restore them to? DVDs are unreliable to rely on 100%. So...
  1. Replies: 5
    Last Post: 30th Sep 2011, 07:33
  2. Replies: 1
    Last Post: 4th Oct 2010, 05:07
  3. Restoring Picture Icons HELP!!!!
    By lelouch283 in forum Computer
    Last Post: 8th Sep 2010, 20:34
  4. How ican get the best picture quality of videos on lcd monitor via pc
    By nusratjaveid in forum Newbie / General discussions
    Last Post: 20th Jun 2010, 06:49
  5. Best Program For Restoring Old Videos
    By PaulDHolloway in forum Editing
    Last Post: 2nd May 2009, 21:40
