Hi,
I have susscefully installed the SVCD2DVD 2.0. When I try to register, it disappears about 30s after the program loads. So I have to do the registration again quickly. And after i done the registration, it disappear again. So I have to restart the program. The program starts normally. But again, after about 30s, it disappear. Any advise would be appreciated.
Thread: Program disappear
What are your Windows language settings?
I am using WinXP SP2, in "Regional and Language Options" tab
Supplemental language support [checked the 1st]
Language used in menus and dialogs [English]
in "Advanced" tab
Language for non-Unicode programs [Chinese (Taiwan)]
Can you change this to English (UK or US) to see if this resolves the problem?Originally Posted by vkyfSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Have it changed to English (US), then start up the progrom. The splash screen shows up and then disappear again.
Can you try reinstalling now that that setting is changed?
Thanks! It is now working.
I have the same problem and I know changing the language setting will work but then other programs will stop working (i.e. fonts won't be displayed properly) Is there any other way to fix it?Can you change this to English (UK or US) to see if this resolves the problem?
subtitles disappear using mpc-hc
By yaniryu in forum SubtitleReplies: 0Last Post: 27th Jan 2012, 11:47 -
Hard drives disappear
By rhegedus in forum ComputerReplies: 12Last Post: 20th Sep 2008, 05:03 -
subs disappear
By bountylord in forum SubtitleReplies: 0Last Post: 21st Feb 2008, 09:32 -
Making backgground disappear
By moviebuff2 in forum Newbie / General discussionsReplies: 11Last Post: 16th Jan 2008, 23:23 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 06:39
