VideoHelp.com Forum
    Im looking for a program that will capture images at a set intervil and auto save them . i want to take screen captures from a dvd but not have to sit there and manually do it
  2. Member Stormin Norman's Avatar
    Welcome to the forum bloodyzombie
    Originally Posted by BJ_M
    you can do this automatic using v-dub and use decimate and save to images ...
    set your in and out points first ..
    Originally Posted by Jethro Clampet
    Best "do it all" capture I've seen or tried is from Snagit.
    www.techsmith.com Snagit. There capture proggy does it all.... makes tutorial videos of the desktop, timed captures in any format and any resolution It's a free trial for 30 days and $19.95 to buy I believe. Execelent proggy. Can capture on a timer from ANY source
    at any value you want up to 1 per second.
    Power DVD and Win DVD are nice that they allow format choice and size but no timed caps and wont work on all types of media.
    With Snagit you can do some really cool stuff.
    By the way, this is from a sticky in the "Newbie Section" labeled "How to capture a photo off a dvd or mpeg file?"
    Hope this helps.
    Quality is my policy.
  1. Videos from screen capture software
    By snafubaby in forum Video Conversion
    Last Post: 18th Mar 2012, 03:35
  2. Replies: 5
    Last Post: 21st Feb 2011, 07:17
  3. Replies: 2
    Last Post: 9th Nov 2009, 19:26
  4. Best video/screen capture software
    By latr0486 in forum Video Streaming
    Last Post: 27th May 2009, 16:58
  5. Capture Software Needed with the Canopus ADVC-110 ??
    By christopheramos in forum Capturing
    Last Post: 23rd Feb 2009, 15:42
