VideoHelp.com Forum
    Hi guys
    well, actually i got some couple question and i'm really dont know how to do, i tried alot time but still need some help!
    I got 8 Drama DVD's and i need compress to 3 or 4 DVD's only so what kind the software i can use to do that?
    my main idea was use DVD Shrink to rip and then merge. but each dvd has menu so how can i rip without those menu?
    if some one could show me the step that willbe great!!
    Thank you!
  2. Member MOVIEGEEK's Avatar
    Use Re-Author but you can't save the menus:
    www.mrbass.org/dvdshrink/
    If you want menus use DVDLab.
    Thanks for reply! well, so does mean DVDShrink can skip the menu?? and then i could use DVDLab to make new menu? what about merge ??
    Thank you
    If you want to keep the menus, use DVD Remake Pro to merge two complete DVDs together with a simple disk 1 or disk 2 menu added at the top. Use either DVD Shrink or DVD Rebuilder to compress them down to fit on a single disk.
    Or
    Use TDA to import just the titles that you want on each disk and build the menus there.
    How long will the running time of each combined disk be ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Well, idont want to keep the menus because i want make one bymyself.
  6. Member waheed's Avatar
    If you dont want to keep the menus, DVD Shrink in reauthor mode.
  7. son of a ......
    i couldn't resist this guy tempting title!!
    COOKIEEE!!!
  8. exteamtoms,
    Your thread title doesn't really describe your problem, and is often passed over by experienced users who would otherwise be able to offer you help. It also means that anyone searching for the same problem in the future can't tell if this post is what they are looking for.
    Please change the title to something suitable.
    Regards,
    Cobra
    Forum Moderator
  1. Compress 50GB avi to one DVD
    By pauldaymond in forum Video Conversion
    Last Post: 27th Mar 2009, 10:53
  2. compress DVD video
    By avextraxjp in forum Newbie / General discussions
    Last Post: 30th May 2008, 18:04
  3. compress ps3 to 1 dvd ?
    By pcb in forum Newbie / General discussions
    Last Post: 26th May 2008, 11:58
  4. Looking for best way to compress dvd backups
    By Wolfsrudel in forum Video Conversion
    Last Post: 2nd Jan 2008, 13:36
  5. How do you compress several DVDs in to one DVD R?
    By Baldrick in forum Newbie / General discussions
    Last Post: 29th Nov 2007, 03:50
