Results 61 to 67 of 67
I have used it,
this is the original video screenshot with channel logo at top right corner.
but when I use this on the video i get the result.....
you can easily find that the result is not good,but if i use the logoaway filter it gives me better then this.
please help me how to ELIMINATE THIS STATIC CHANNEL LOGO.
Re-read the introductory post of this tutorial. It only works with white transparent logos. Yours is a solid, multicolor logo. A better option would simply be to blur it.
Just leave it alone.
All you'll do is make it look worse and more annoying.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Half joking suggestion...
replace the logo with an image of like a Salvation Army Donation can, that way your brain simply removes it for you...or maybe an image of a personal failureMy plasma's only 42 inches, but I sit 24 inches from it. It's pretty cool.
Hey guys! Great guide! i've used it for years with great results but now i can't seem to make it work with hdtv .ts files (1920x1080 res) : when u load the two frames then u go to the delogo window and sample frame, frame1 then on show preview window the pointer that moves to frame2 disappears and u just cant move to next frame to sample frame it and complete the process. does this just not support hd files or is there a trick to it? thanks for the help.
Avidemux- Removing Filter From Altered Video?
By Smizzle in forum EditingReplies: 7Last Post: 20th Jun 2011, 16:41 -
How do I make a filter for VDub
By blaze01 in forum Newbie / General discussionsReplies: 4Last Post: 4th Mar 2008, 16:16 -
Merits of the delogo filter
By lordsmurf in forum RestorationReplies: 26Last Post: 10th Dec 2007, 06:09 -
ACDsee Filter&VDUB
By mv0930 in forum Newbie / General discussionsReplies: 0Last Post: 4th Sep 2007, 12:27 -
Vdub Filter Chain
By christopheramos in forum Video ConversionReplies: 16Last Post: 3rd Sep 2007, 07:57
Of course, I don't speak for everyone here, and many still do their filtering in VDub.
