VideoHelp.com Forum
  1. Is there a patch? A comparable free program that will work?
  2. Member mats.hogberg's Avatar
    For what? Shrink is for backing up/transcoding commercial discs, mostly.
    /Mats
  3. what for are you trying to edit? or make copies? Either way your best bet is to rip it to your hard drive and burn it from there. That's how I've done it, and if you want to edit, you're better off just capturing it into an editable format. Format encoders and converters didn't seem to work for me.
  4. Originally Posted by Memo_182
    This camera spits out "eneditable", half hour mini DVDs. It creates clips and finalizes with a cheesy menu --- click the clip you want and away you go.
    I want to pick the clips I want, maybe shorten them in DVD Shrink and then burn them onto a new, full-sized DVD in the order I want. The thing is, they seem to want to stay loyal to their respective menus they recieved when they were burned in the camera. Can I strip them down and line them up?
    Then, I make copies.
    Also, when you say "capture" into and editable format, do you mean to say "Get a different camera" or do you mean capture it analog style into a hardware or software recorder?
    No offense, but you will find in quick time that Mini DV was a bad choice if you want to capture and edit using a PC using the DV Disc it creates. It's just a gimmick to lure the consumer in, just like the drive thru at McDonalds. We all want it fast and now!
    If you can play this dvd on your dvd player then you can rip it with dvd decriptor. Then dvd shrink can read it. If dvd shrink can not read this then your doing something wrong.
  1. Sony Handycam DCR-HC42 can no longer read/write to tapes
    By tgp1994@gmail.com in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 11th Jan 2011, 16:09
  2. How do you fix a Sony dcr-trv315 handycam that won't record on tapes
    By tyty66 in forum Newbie / General discussions
    Last Post: 9th Oct 2010, 07:20
  3. Import from mini DVD on Sony Handycam camcorder
    By usctrojan98 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 3rd May 2009, 13:53
  4. Cannot read sony handycam dvd-r
    By DKIT in forum Newbie / General discussions
    Last Post: 3rd Apr 2009, 13:56
  5. Replies: 3
    Last Post: 22nd Jan 2008, 08:18
