Basically, a Font and Font Size other than the one I am selecting under Filters is being burned to the AVI. Hoping to get some help ... been running into this problem over and over...
Source file is an AVI file. SRT file is the subtitle file. Target format either XviD or DivX via mencoder.
Load the SRT file under Filters. Burn is checked. Select LiGothic, size 4, Pos 80. Text encoding standard ISO-8859-1.
Preview looks perfect. Encode.
And...it looks like Arial, size 0.
Any advice/help appreciated. Couldn't find anything on this on the boards, and I really need to have a bigger text size than what's being output. Am using v0.0.9t.
Thanks in advance!
Results 1 to 9 of 9
Try to revert to the old binaries http://prdownloads.sourceforge.net/m...5.zip?download (0.0.9t can use them) to see if it changes anything.
Yep, reverting to the old binaries did it. Thanks major!
Then it is something in the binaries. I'll build new ones soon.
I ran into the same problem this afternoon, but thanks to the forums, using the older binaries did solve my problems. Thanks to you too major, but any idea when is the newer version coming out? ffmpegX is the daily tool for my mac! Best ever!
Could this be the solutions to my prayers?
Lets give it a try.
Not quite sure what older binaries mean, guess a older version of ffmpeg, but if this has work for you should work for me.
Best wishes,
Huifa."Everything happens for a reason"
oops.
I download the binaries but I do not have any clue of how to use them.
Any help here guys, how do they work with ffmpegX?
Regads,
Huifa.
Never mind did all by myself and proud of it.
Thanks for this topic,
Kisses for all of you guys,
The problem is still there with the binaries for 0.0.9u
Subtitles are Arial size 0, regardless what you choose.
Yet again: how add .srt subs to .avi for burning on DVD?
By VenusAndMars in forum Authoring (DVD)Replies: 10Last Post: 17th Jan 2011, 01:34 -
How to change srt Subtitle style and font size in MEGUI ?
By DARIFBS in forum SubtitleReplies: 4Last Post: 12th May 2010, 14:19 -
.SRT Font Size When Playing Using Flashdisk On Stand-alone DVD Player
By randy3101 in forum SubtitleReplies: 5Last Post: 9th Apr 2010, 00:48 -
Creating my own subs for avi & editing subs of ogm & mkv
By retroborg in forum SubtitleReplies: 1Last Post: 1st Jan 2008, 14:33 -
Missing subs, size & font can't be changed
By Jacke in forum ffmpegX general discussionReplies: 2Last Post: 17th Aug 2007, 12:04
