I am trying to get my firmware updated on my DVP642, the player does not play the some of the XVid's I have, the video is messed up, I am wondering if a firmware upgrade will work to fix this. Phillip's site no longer has it available for download, can anyone tell me how i can go about getting the Xvid's to work or updating the firmware?
thanks
do u have any issues with playing dvd movies?
1109 only appeared to add MacroVision
NONE of the firmware upgrades corrected any playability issues. You will need to reenocde the xvid files that don't work.
The video problem is a known issue. Try pressing the system menu button, then exit back to the movie.Google is your Friend
Press system-menu button 2 times immidiatly when the movie starts.Good luck.Originally Posted by money69
If you follow the link
http://forum.rpc1.org/portal.php
maybe you will find what you are looking for or maybe not.
Here is a link for the official 0112 firmware for the DVP630/00 which will also work for the DVP642/37 (and DVP642/17).
DVP630 Firmware
More information on file issues/fixes can be found here: http://groups.google.com/group/alt.v...e=source&hl=en
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 18:45 -
Phillips DVP642/37 help with DTS Audio problems
By cram_it_2000 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 24th Sep 2008, 14:29 -
DVP642 - Did they ever update the Firmware?
By kelemvor in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st May 2008, 08:50 -
phillips dvp642
By bored23 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Mar 2008, 06:54 -
Makeing NeroDigital Run on a Phillips DVP642
By Trident5 in forum DVD & Blu-ray PlayersReplies: 18Last Post: 1st Mar 2008, 23:13
