I want to change video speed from some part of video file in time line, but when I change the rate of speed it's change whole speed of video not only of selected clip in time line. Help!
Regards.
Thread: Vegas video speed control
QUALITY HAS A NAME
I'm not sure what the proper solution would be, but a workaround would be to render only the video with the speed change, then import that into your project.
Hello,
You can change the speed on only a selected portion of clips.
Make sure the clips is on the timeline and split (before and after ) so as not to affect the rest of it.
Move your cursor over the right end of the clips and you will see a wiggly box and line appear.
Now start dragging the clip LONGER.
Gives the effect of slow motion however, do not do this with the audio. You will need some audio there (music , whatever)
By the way, this is found in the vegas manual
Hope it helps....
Look up Velocity Envelopes in the help files. They will allow you to add points along the timeline and vary speed up or down, bring it to a dead stop then start it up again, or even reverse it. Add as many points as you need to do this, change the way acceleration occurs. Very powerful, and does not require splitting of the clips.
Use "s" to split the video seperate from the rest of the clip (front & back). Then click & drag the end of the clip you want to slow down or speed up.
Boda
I thought it was CTRL-click and drag the ends of the clip for speed. A regular drag just changes the in-out point of the clip...
Originally Posted by SoundFX
Sorry.....
Your right, it's Ctrl + click & drag at the end of the clip.
Boda
How to control transition length in Vegas Pro 10?
By gutterboy in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Editing .264 video from mini-cam in Vegas: Vegas won't read video
By bigass in forum EditingReplies: 3Last Post: 27th Dec 2010, 11:35 -
All-in-One Volume Control? Vegas 6
By solarblast in forum AudioReplies: 2Last Post: 6th Dec 2008, 09:07 -
How to incr./speed up frames per second faster than 4x in vegas m. studio 6
By ff27 in forum EditingReplies: 1Last Post: 1st Apr 2008, 20:58 -
How to speed up rendering time in Vegas? PS3
By Abiyad in forum EditingReplies: 4Last Post: 25th Jan 2008, 17:45
