VideoHelp.com Forum
    Can Someone either point me in the right direction or offer any help with the creating a DVD from 2 BIN files. I have followed the instructions and it APPEARS to be converting but the final product is just the first file being put on the disc.
  2. Member ChrissyBoy's Avatar
    Are you putting the 2 bin files in the same TitleSet?
    if by that you mean am i putting both assetts into the program together then yes i am and in numerical order then using quick dvd and burn
  4. Member ChrissyBoy's Avatar
    Do you get two 2 movie reels (TitleSets) or one after you do "Quick DVD"?
    Got it sorted now thanks for your help
  1. Svcd2dvd stopped working
    By H4MST3R in forum SVCD2DVD & VOB2MPG
    Last Post: 12th Apr 2011, 21:53
  2. SVCD2DVD Stopped Working
    By magic90 in forum SVCD2DVD & VOB2MPG
    Last Post: 28th Sep 2010, 07:07
  3. svcd2dvd ffmpeg has stopped working adding dvr-ms
    By Pooch917 in forum SVCD2DVD & VOB2MPG
    Last Post: 1st Mar 2010, 09:00
  4. svcd2dvd not working with new MKV's
    By Logical in forum SVCD2DVD & VOB2MPG
    Last Post: 21st Jan 2010, 16:27
  5. SVCD2DVD 2.5.5030 Not Working with Vista SP2
    By k_vic in forum SVCD2DVD & VOB2MPG
    Last Post: 28th May 2009, 12:33
