VideoHelp.com Forum
Results 1 to 9 of 9
    When I'm muxing an avi video plus 1 mp3 audio I get the following error:
    ffmpeg version CVS, build 3211265, Copyright (c) 2000-2004 Fabrice Bellard
    configuration: --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
    built on Aug 14 2005 14:46:34, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
    Could not find sync stream #0.1
    OK, I'm back to 0.0.9s. Everything works fine in the old version.
    This is what I wanted to try:
    I demuxed an ogm, resulting in an avi with only one stream (video, no audio). Then I converted the extracted ogg audio to mp3 and wanted to mux the avi video with the mp3 audio.
    This works perfectly in the old version, but the new version complains about not having an audio stream in the avi (well, that's the point about muxing, isn't it, because the avi has no audio yet
    BTW major, you should keep a download link to the previous version on your site for people like me who want to fall back. I had to search for a while until I found a download link to the old version.
  3. I'll test this, thank you for reporting.
    I have the same problem with the latest version of ffmpegx...
    I need to mux an avi with an mp3 to get a video_ts.
    How can I do that?
    I had the same problem in 0.0.9t-r2. Then I downloaded 0.0.9t-r4 and at first it seemed to work but in fact it didnīt anything, there was nothing in the log but cpu was at 100%.
    Eventually I had to kill the ffmpeg2 process using Activity Monitor.
    So, where can I get 0.0.9s?
  6. Originally Posted by MetalSnake
    Where can I get 0.0.9s?
    http://homepage.mac.com/major4/ffmpegX_0.0.9s.dmg
    Thanks, but is doing the same as 0.0.9t-r4 does
    Am I doing something wrong here?
    I go to Tools, on the right I click choose and choose an .avi file, then I click the 2nd choose button and choose a .mp3 file then choose AVI+audio (the original .avi already has audio) and click on Mux…
  8. Try with a small test clip to check if the problem was in the file or in the tool.
    I tested it with a short .avi and .mp3 file, it behave the same as with my bigger .avi and .mp3 but it after 1 minute it said it is done and I had the new file in the .avi folder.
    So I though I werenīt patient enough, but now itīs running since 1 hour for a 347mb .avi and 40mb .mp3 still nothing.
    Iīm no an iMac G5 1.8GHz with OS X 10.4.2
  1. Need Help muxing to AVI
    By ChrisDaMan in forum Video Conversion
    Last Post: 3rd Mar 2011, 18:58
  2. Sync issues after muxing AVI files
    By FatalX in forum Editing
    Last Post: 23rd Dec 2009, 20:33
  3. [AVI] Muxing aditional audio
    By Wacken88 in forum Linux
    Last Post: 25th Jun 2009, 09:56
  4. CLI for muxing MP3 into AVI?
    By RogerTango in forum Video Conversion
    Last Post: 14th Feb 2009, 21:37
  5. Winsubmux error. Plus submux not muxing
    By Codecoder in forum Authoring (VCD/SVCD)
    Last Post: 12th Jul 2008, 22:30
