VideoHelp.com Forum
  1. ok I am using Adobe Audition to convert wave to mp2 because HeadAC3he does not have a batch. I would like to know what settings I should I put for Adobe Audition for DVD. Here's are the options
    :Compression:
    :: Layer 1
    :: Layer 2
    :Psychoacoustics:
    :: Model 1 - MUSICAM
    :: Model 2 - AT&T
    e-emphasis for decoder:
    :: None
    :: 0/15 microseconds
    :: citt j.17
    ata Rate/Compression Rationot standard bitrate)
    :: 32 K-bit/sec, 0.74 bits/sample
    :: 48 K-bit/sec, 1.11 bits/sample
    :: 56 K-bit/sec, 1.30 bits/sample
    :: 64 K-bit/sec, 1.48 bits/sample
    :: 80 K-bit/sec, 1.85 bits/sample
    :: 96 K-bit/sec, 2.22 bits/sample
    :: 112 K-bit/sec, 2.60 bits/sample
    :: 128 K-bit/sec, 2.97 bits/sample
    :: 160 K-bit/sec, 3.71 bits/sample
    :: 192 K-bit/sec, 4.45 bits/sample
    :: 224 K-bit/sec, 5.20 bits/sample
    :: 256 K-bit/sec, 5.94 bits/sample
    :: 320 K-bit/sec, 7.43 bits/sample
    :: 384 K-bit/sec, 8.91 bits/sample
    :: Enable Error Protection
    :: Copyrighted Material
    :: Original Material
    :: Joint Stereo
    remember it's for DVD
  2. Member daamon's Avatar
    You can use ffmpeggui to easily convert WAV to MP2.
    If you're wanting to do batch encoding, drop a PM to jimmalenko as I know he's created a GUI front end for batch processing that is really good and useful.
    He's not releasde it yet - I don't if it's coz he's shy, busy, lazy or greedy (@ jimmalenko: )
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member Cornucopia's Avatar
    :Compression:
    :: Layer 1
    :: Layer 2
    :Psychoacoustics:
    :: Model 2 - AT&T
    :: None
    :: citt j.17
    :: Joint Stereo
    That's a start-you can choose from one of those bitrates depending upon you video filesize needs, quality, etc.
  1. Adobe Audition 3 Crashing at Start up
    By EmpireStrikesBack198 in forum Audio
    Last Post: 29th Nov 2011, 10:35
  2. Adobe Audition 3.0 imports as 32-bit
    By ranosb in forum Audio
    Last Post: 29th Jun 2011, 00:35
  3. Adobe Audition
    By nic3 in forum Audio
    Last Post: 27th Jan 2011, 12:36
  4. Replies: 11
    Last Post: 2nd Jan 2011, 03:53
  5. Adobe Audition Mixdown Problem
    Last Post: 31st Mar 2010, 15:24
