The only way i could find to add subtitles to a DVD is from this link:
http://www.videohelp.com/forum/viewtopic.php?t=245188
It works for me but there is one problem....I DONT HAVE ANY DVD'S WITH SUBS ALREADY IN THEM....thus means i dont have dvd colours at all. Sorry that i dint posted this in the properly forum (like the link above) but since its DVD autoring i thought this might be the right one.
My question is: Thus anyone know a better subtitle creator program (other that the one mentioned in the link, that program sucks) and the codes of the colours for the .ifo file of the DVD.
TNX.
Results 1 to 10 of 10
you could copy colors from some other dvd with subs.
...or experiment. There are 16 color registers to play with. Use IfoEdit, open the pgciti (IIRC) branch, and change the vaues. 000000 is full green. First 2 hex digits are blue (again, IIRC) the second pair blue and last intensity.
4 of the 16 available registers are used - you just have to find which.
/Mats
Well you could use the example ifo from SubtitleCreator... load that up & your new one in IfoEdit & do:
I think even if you have not a subs in the original DVD, you still have color tables in the .ifo.
...which may or may not match the subs he's got...
/Mats
Open the finished DVD in PGCEdit and change them to whatever you want.
The original colors are taken by the Subtitle creator at the creating stage - so they will match.Originally Posted by mats.hogberg
I would like to say thanks: ill try it once more time wiht Subtitle Creator.
Second: sorry to the Admin by me posting another post like this one....Sorry i tried but could not find this post of mine.
One way to find and reply to threads you've posted in is to click on that advanced search button at the top of the page. When it takes you to a new page, type your name in the "Search For Author" box, and up will pop a list of the threads in which you've posted.
Mpeg2 Compliance and DVD Autoring.
By sambat in forum Authoring (DVD)Replies: 4Last Post: 22nd Apr 2012, 07:50 -
Need help DVD Multi disks Parellel Autoring
By mitz in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 00:23 -
Autoring with DVD Lab
By mogoyon in forum Authoring (DVD)Replies: 4Last Post: 12th Feb 2010, 11:08 -
Autoring from Sony DVD Arch2.0, pls help
By jazu in forum Authoring (DVD)Replies: 5Last Post: 23rd Nov 2009, 06:05 -
Subtitle colours in subtitle creator
By Belfour in forum SubtitleReplies: 3Last Post: 22nd Oct 2009, 02:00
