VideoHelp.com Forum
  1. Member mummer43's Avatar
    I am using Samsung 4x DVD+RW's and it is not recognizing them. Any thoughts on what the problem might be?
  2. http://www.videohelp.com/dvdplayers....y=Name&hits=25
    This is the VideoHelp record for your DVD player - it appears to be a very capable player and can certainly read DVD+RWs. Further to this...
    http://www.videohelp.com/dvdmedia.ph...+or+List+Media
    ...your media seems to be pretty solid, too. I am assuming that the disc isn't scratched up, so it's got to be an issue either with your burner, maybe the disc, or whatever you are trying to burn.
    Could you please answer the following questions for us? I'm by no means an expert when it comes to this, but the more detail you provide the more likely you are to get a good, working answer. Here goes:
    - What are you trying to burn? Is it a DVD (as in .VOB files etc.) or a DivX/XviD file?
    - What application are you using to burn it (eg. Nero)?
    - Does the disc you burned work on any other DVD players? Can your PC read it? Have you tried using another disc?
    Hopefully, we can sort this out with a little more detail.
    Cobra
  3. Member mummer43's Avatar
    Originally Posted by Cobra
    http://www.videohelp.com/dvdplayers.php?DVDname=DVP642&Submit=Search&Search =Search&chipset=&country=&orderby=Name&hits=25
    Cobra
    I am trying to burn a tv show that I recorded using WinTV. It's in .mpg format. I am using Nero and it did work on my computer. I will try it again today.
  4. Member mummer43's Avatar
    Ok, I got the menu to come up, but it still won't play...
  1. Remote for Philips DVP642
    By Melina in forum DVD & Blu-ray Players
    Last Post: 10th Jun 2010, 21:54
  2. PHILIPS DVP642... how do I upgrade the firmware?
    By mummer43 in forum DVD & Blu-ray Players
    Last Post: 14th Jan 2009, 18:45
  3. Replies: 9
    Last Post: 23rd Jul 2008, 04:33
  4. Problem playing AVI on Philips DVP 642K
    By yohu123 in forum DVD & Blu-ray Players
    Last Post: 20th Aug 2007, 09:28
  5. Output resolution for Philips DVP642
    By cheerful in forum DVD & Blu-ray Players
    Last Post: 2nd Aug 2007, 23:41
