I've searched the forums for an answer, and while I've learned what to use, I haven't found out how to do it. I'm trying to get recorded shows off my Moto 6412, which is connected to my XP pc via firewire and CapDVHS. I can watch the .ts files with VLC media player, but I haven't yet found the utility that will save those .ts files as MPG. Ironically, I can easily convert HD content with HDTVtoMPEG; it's the NTSC content I can't manage to do. What tools should I be looking for? Thanks.
I use HDTVtoMPEG to edit both my HD and SD captures. And you can change the extention CapDVHS uses from ".ts" to ".mpg".
Wolf -
ProjectX worked (after a bit of fiddling and searching) -- thanks, Soopafresh!
HDTV2MPEG won't work for me on NTSC files; the little preview window is blank, and I think the resulting file was empty too. Can't remember (I've tried so many things!); I'll have to try again.
Does changing the file extension in CapDVHS change the type of file you get, or just the name?
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
How to convert MPEG-4 into MPEG-2 with a Mac
By VidHunter in forum MacReplies: 12Last Post: 29th Oct 2007, 01:23 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 23:36
