Hi, I have recently moved to Canada and picked up a Philips MX3910D home cinema system which I am really pleased with as it will play any DVD (I have used the multi region hack and play Region 2/4/region free in both PAL and NTSC) and MP3's / JPEG's from both CD's and DVD's. So far so good and the sound system is great too.
Now the problem I have is that the system is hooked up using the three component cables and during PAL DVD playback the video signal appears to disappear for a second or two every now and again (sound from the unit continues. The TV (plasma) registers this by giving a "no signal" message. This probelm does not appear to happen if I hook up a composite video lead ( or on a NTSC DVD).
I want to keep the component connections for the better quality but can't understand why I should get the problem in the first place. Could it be a faulty unit or what ?
Any ideas or cures ? Many thanks.
Results 1 to 1 of 1
DVD "no signal" with component connection
By medic in forum Authoring (DVD)Replies: 7Last Post: 31st Mar 2012, 18:23 -
Card for capturing HD Component Signal
By peez in forum CapturingReplies: 4Last Post: 10th Nov 2009, 09:42 -
Philips DVDR3590h and no signal detected
By m_fardan in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2009, 13:07 -
Any way to make Philips DVP3960/37 upconvert through component?
By gzsfrk in forum DVD & Blu-ray PlayersReplies: 21Last Post: 23rd Nov 2008, 23:00 -
Component video signal->TV problem
By nathanaa in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2007, 21:37
