Question
Can anyone recommend a quality Streaming Video Recorder app that records directly to DVD standard Mpeg 1 or 2?
Situation
I am a paying licensed subscriber to a video site that encodes its files with DRM. I have no problems watching the files on my desktop which holds the files. However, I spend much of my time on the road with my laptop. I have found a "work around" for being able to bypass the DRM. The problem is that it takes hours of converting to Mpeg.
My system is to download the DRM protected video file to my HD. I then play the file in WMP 10 and capture it using FRAPS screen capture app. The resulting AVI(s) are huge, usually close to 100 gb. I then have to use TMPGENC to convert them to useable Mpeg format.
I use FRAPS for several reasons:
-Easy to setup and use
-It has lossless capture
-It handles huge files easily
-It captures only the video, so there’s no need for croping later on.
The only downside is the huge AVI files and the lengthy process of converting to MPEG.
I would greatly appreciate any feedback on better mpeg capture apps, any methods i can use to shorten the conversion process, or any other faster methods for completing this process, thanks.
Tmpgenc is a great encoder, but it is slow - VERY slow. If you're willing to choose the non-Mpeg route, VirtualDubMod and the Xvid codec will convert uncompressed AVI files at 15fps on my junky 2.4Ghz P4. Not too bad. Choose a high enough bit rate in Xvid (>2000) and you should end up with some nice looking files which will be even smaller than Mpeg2s.
VSO Software's DivXtoDVD will encode your AVI to DVD compatible VOB files at 25fps or faster. If you insist on MPEG, this is probably the fastest app out there. Download the freeware version, as it is faster than the shareware one at the moment.
dvd recorder that records PAL and NTSC
By ecc in forum DVD & Blu-ray RecordersReplies: 4Last Post: 8th Jan 2009, 02:53 -
Netflex streaming movies directly to your TV
By rcguy1 in forum Newbie / General discussionsReplies: 2Last Post: 5th Oct 2008, 13:46 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58 -
+r recorder now records -r disks
By kshavo in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th May 2008, 01:31 -
DVD Recorders that records to + media?
By SteveMKIIDub in forum DVD & Blu-ray RecordersReplies: 5Last Post: 21st May 2007, 11:54
Statistics
Newest guides
Latest tool updates
New media comments
