I extracted a 30 chapter from a DVD as a .vob - when I try to encode with either the h.264 (mp4) or the mov (mp4) quick presets I end up with a file that is 0 kB.
mov preset:
Encoding started on Sun Aug 28 05:00:38 EDT 2005
Input #0, mpeg, from '/Users/Lee/Movies/HS.vob':
Duration: 00:00:35.5, start: 366.952778, bitrate: 6485 kb/s
Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 29.97 fps, 9800 kb/s
Stream #0.1[0x20]: Subtitle: dvdsub
Stream #0.2[0x21]: Subtitle: dvdsub
Stream #0.3[0x22]: Subtitle: dvdsub
Stream #0.4[0x23]: Subtitle: dvdsub
Stream #0.5[0x24]: Subtitle: dvdsub
Stream #0.6[0x25]: Subtitle: dvdsub
Stream #0.7[0x26]: Subtitle: dvdsub
Stream #0.8[0x84]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.9[0x27]: Subtitle: dvdsub
Stream #0.10[0x89]: Audio: 0x0000
Stream #0.11[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream #0.12[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.13[0x83]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Codec type mismatch for mapping #0.1 -> #0.1
h.264 preset:
Encoding started on Sun Aug 28 04:56:19 EDT 2005
MEncoder dev-CVS-050814-13:46-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x1b78000
MPEG-PS file format detected.
VIDEO: MPEG2 720x480 (aspect 3) 29.970 fps 9800.0 kbps (1225.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
Opening video filter: [expand osd=1]
The selected video_out device is incompatible with this codec.
Also try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=352]
Opening video filter: [pp=0x33]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred csp: Mpeg PES)
[PP] Using external postprocessing filter, max q = 6.
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG-1 or 2 (libmpeg2))
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 2 -> 2
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
using SAR=352/359
x264 [info]: using cpu capabilities Altivec
1 duplicate frame(s)!
demux_mpg: 24000/1001fps progressive NTSC content detected, switching framerate.
Flushing video frames
Fixing AVI header...
Video stream: 195.558 kbit/s (24444 bps) size: 870696 bytes 35.619 secs 854 frames
slice I:8 Avg QP:22.00 Avg size: 7668
x264 [info]: slice P:844 Avg QP:22.01 Avg size: 953
x264 [info]: slice I Avg I4x4:35.5% I8x8:0.0% I16x16:64.5%
x264 [info]: slice P Avg I4x4:0.4% I8x8:0.0% I16x16:1.9% P:21.0% P8x8:0.9% PSKIP:75.7%
x264 [info]: kb/s:195.0
ffmpeg version CVS, build 3211265, Copyright (c) 2000-2004 Fabrice Bellard
Codec type mismatch for mapping #0.1 -> #0.0
Seems there is a problem creating the aac audio?? No
XviD and DivX quick presets work fine on this vob though.
It seems that stream 1 is a subtitle, so you cannot convert it to audio. As you can see in the output, the audio in this VOB seem to be in stream 8, 11, 12 and 13. Try to select 12 as audio track and check again.
Where do you select the track?
In the audio tab there is 0-9 and any one of those I selected resulted in the same output.
Indeed, I need to put more tracks in the audio popup. In the meantime, encode from VIDEO_TS instead as from VOB. You should not get any problems in that case, as only the available audio tracks will be listed in the popup.
Yeah VIDEO_TS is no problem - but I like to extract a 1 minute or so chapter and then try various settings.
Also I tried demuxing the vob into streams but when I try to mux back in only one audio stream with the video I always seem to get errors.
Another thing I was wondering is if 5.1 ac3 to 5.1 AAC works.
Thanks for the help!
Extract the chapter with only one audio stream and no subtitles.Originally Posted by live4ever
AAC support is ony stereo for now.
Transcode to mp4/h.264 - is there a generic high-quality preset? (xmedia)
By TYLER08027 in forum DVD RippingReplies: 0Last Post: 13th Jun 2010, 16:43 -
Quick AVI Creator 1 pass xvid preset?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 17th May 2010, 16:25 -
Would like better winff h.264 mp4 preset.
By Verlager in forum LinuxReplies: 26Last Post: 16th Jul 2009, 19:24 -
Converting AVI to iPod h.264 preset
By oldskoolboarder in forum ffmpegX general discussionReplies: 1Last Post: 29th Oct 2007, 16:17 -
Suggestion-Editable quick preset
By ilmz in forum ffmpegX bugs and suggestionsReplies: 0Last Post: 22nd May 2007, 16:52
