VideoHelp.com Forum
  1. Member nzo's Avatar
    I've never frameserved before and I don't know what I'm doing.
    I'm using Vegas 6, DeBugMode's FrameServer and CCE 2.67. I want to frameserve a project from Vegas to CCE. I've installed the frameserver plugin in Vegas and can access it via the Vegas's RenderAs menu.
    What I don't understand is how my Vegas project gets into CCE.
    The frameserver dialog merely asks me to specify a new filename, then it does its thing.
    I'd assumed the frameserver 'sits' between Vegas and CCE but there is no mention in the frameserver's set-up dialog related to CCE, so I'm misunderstanding something in the process.
    What do I need to do? I've searched high and low but have come across nothing that explains it clearly enough (for me).
    Thanks and appreciation!
  2. Член BJ_M's Avatar
    there is a complete guide at debugmode
    you just load the temp file you made into cce and thats it ...
  3. Член BJ_M's Avatar
    and dont close vegas
  4. Member nzo's Avatar
    Thanks BJ_M (again).
    Be assured that if I had fully understood the DebugMode guide, I wouldn't have asked here.
    If only the writers of guides understood that the slightest assumption of know-how can make it nearly impossible for struggling newbies like myself to understand.
    I've since found the following that made sense to me, in case other confused newbies happen to pass this way:
    Q. What is "frameserving" and what does it do?
    A. A frameserver creates a fake .AVI file that other programs such as CCE etc can load and use. This fake .AVI file contains only a few frames and as the conversion/encoding program (CCE etc) requires it, the frameserver serves more frames to it. Hence the name frameserving.
    Different strokes for different folks
    But hey BJ_M, I appreciate your help!
    Cheers.
    [/b]
  5. Member nzo's Avatar
    Here's another useful link I came across:
    http://www.digitalvideoclub.com/tuto...frameserve.php
  1. Frameserving from Sony Vegas into MXF format
    By 24fps in forum Video Conversion
    Last Post: 8th Feb 2012, 08:57
  2. Hi from The Land Down Under
    By ScottMyob in forum Newbie / General discussions
    Last Post: 17th Jul 2011, 18:43
  3. Replies: 6
    Last Post: 1st Feb 2010, 20:31
  4. FrameServing from Vegas 9 to MeGUI
    By Kit-10 in forum Newbie / General discussions
    Last Post: 4th Dec 2009, 17:12
  5. colors shift when frameserving from Vegas
    By crisciunas in forum Video Conversion
    Last Post: 16th Oct 2009, 16:24
