Hi there!
Okay, before I start I wanted to make clear that I have already searched the forum for this, and that I am aware of the fact that it has been discussed here several times. But there never has been any solution for it, the threads always seem to end with the sentence "it's still out of sync", which brings me to my problem:
When I encode VOB files from DVDs with 5.1 sound with ffmpeg (mencoder doesn't support AC3 5.1, does it), the audio or video is out of sync. Also, the delay is always the same, no matter which bitrate I use for the sound. Well, that's the thing now...
Please help, thanks.
Results 1 to 9 of 9
Hello,
sorry, have I been impolite? Please answer, still having the same problems. Or does 0.0.9t solve the problem?
Cheers, Martin.
Not to come off sounding like a prick, but why don't you use AutoGK?
It has to be the best and stable app for DVD to AVI.
Ops! Didn't know this was MAC
This is a Mac OSX forum.
Have tried "passthrough". With ffmpeg-engine the out-of-sync problems are the same. Weird thing is: Sound seems to start playback anew when shuffling forward using MPlayer OSX (each version). When I just let it play, the out-of-sync is also there, though. VLC playback of sound doesn't work at all.
mencoder-engine transforms 5.1 to stereo when using "passthrough" automatically.
Still using 0.0.9s. Do the enigines in t work differently?
Cheers, Martin.
PS: Do I need to register "t" again?
[EDIT] PPS: Tried it with 0.0.9t Trial: Same effect exactly. Can anyone confirm this? Virtually any .VOB file, be it one DVD chapter extracted with MacTheRipper, Preselect DivX or XviD ffmpeg, Audio Passtrough (if source is 5.1), or Audio AC3 5.1.
Hi there,
just wanted to let you know, that the problem is still there.
Can anyone confirm this? I know of many people in the past who had the same problems. Did you solve them? Major, are you not having the problems when encoding 5.1 sound avis?
Cheers, Martin.
I'm researching about sound sync for MP4 H264. About other formats, I advise to check if 0.0.9s worked, so as I can track which differences may be relevant. 0.0.9s can be found at http://homepage.mac.com/major4/ffmpegX_0.0.9s.dmg
0.0.0s didn't work either. Exactly the same problem. Only AC3 5.1 target files. Only engine even generating true 5.1 is ffmpeg, so source is always VOB. No matter what bitrate.
Cheers, Martin.
Audio sync issues - H264 and AC3
By xtrattitude4u in forum Video ConversionReplies: 0Last Post: 6th Sep 2011, 02:22 -
Strange AC3 mkv sync issues
By MarkyMarky in forum AudioReplies: 6Last Post: 6th Jan 2011, 08:40 -
DVD vob to AVI using Handbrake and lip sync issues viewing on PS3?
By GolfGTdude in forum Video ConversionReplies: 0Last Post: 13th Sep 2010, 14:53 -
Demuxed VOB into M2V and AC3 -- Sync issues
By jj_30 in forum ProgrammingReplies: 0Last Post: 16th Jul 2009, 12:38 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
