Hello,
I need to make it region free!
Are there any buttons to hold to do so?
cheers
herman
No.
You shouldn't have bought a Sony.
do you have any good chooices for me.
Are there any "easy" dvd players out there which can be opened up with just a simple "button pressing"
cheers
herman
I have the Philips DVP642 (DVP630 in europe), and that is easily unlocked by pushing 5 buttons on the remote control.
1. Open loading tray
2. Press on the remote: 7, 8, 9, ok, 0
Generally speaking, Philips is user friendly in regards to changing the region code. I think LG is okay too.
There is a section in the menu to the left called "DVD Hacks". You should check there to see if there is a solution to changing the region setting before you buy your next dvd player.
Yes, of course there is an unlock method.Originally Posted by giannid
This works perfectly for the model stated:
http://www.selen.org/sonydvd.html
Need help to unlock Vsonic DVP 8C0
By sierradave in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Dec 2010, 13:09 -
SONY DVP-SR-500H, anyonw have any idea how to unlock it?
By elonn in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Nov 2010, 20:24 -
Unlock code for Sansui DVP 1011
By frank271 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jun 2009, 17:12 -
[Help] Unlock Sony DVP-NS78H DVD Player
By RMO in forum Newbie / General discussionsReplies: 9Last Post: 3rd Apr 2008, 15:59 -
Unlock for Sony DVP NS305, without a numbered remote or palmpilot/PC?
By Jessminka in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Sep 2007, 11:46
