it is based on FFMPEG and encodes to only FLV (flash) format ,... and its free
Transode your existing videofiles to the advanced Flash Video (FLV) format with this free Riva FLV Encoder.
After selecting a source-file you can easily transcode it into Flash Video using one of the presets or your custom settings.
To view the result Riva FLV Encoder comes with the free Riva FLV Player.
If you want to tell a friend, just pass this Link: www.rivavx.de?encoder
At present you can transcode the following formats: AVI, MPEG, Quicktime, WMV. View the online-help with all supported codecs here.
NEW: The new Riva FLV Encoder 1.2 supports exporting images from a video as JPEGs
When you use the Riva FLV Encoder in combination with the Riva Producer or Riva Producer Lite you can use batch encoding with the library.
Download your copy of free Riva FLV Encode
http://rivavx.com/index.php?encoder&L=3
they also have a free player
Results 1 to 1 of 1
Thread: Riva FLV Encoder
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 13:53 -
Encoding for Riva FLV Encoder
By seven_deuce offsuit in forum Video ConversionReplies: 9Last Post: 11th Nov 2007, 03:47 -
Riva flv encoder and windows movie maker trouble.
By michigan2101 in forum Video ConversionReplies: 3Last Post: 29th Aug 2007, 22:23 -
Riva FLV Encoder 2.0 Problems
By link2009 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2007, 12:16 -
Help with Riva Encoder, or Super, HELP!
By atomic22 in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2007, 04:51
