Hi,
This is the first time I tried doing something like this, so please bare with me.
I have copied a video to DVD using my DVD recorder. I now want to use my computer to put a nice DVD menu on the DVD etc.
I have looked at the structure of the DVD and there are a few files on there, and 4 .Vob files which I am assuming contain the movie.
I have been playing with TmpGenc Mpeg trying to get that to read in the files, which it can do but it fails with the audio, stating that it can only support MPEG-Audio, Linear PCM. It cannot even recognise the format.
Am I missing something?
I am assuming I need one large mpeg file that I can feed into a DVD authoring tool, so that I can add the menu etc.
Any help would be greatly appreciated.
Many thanks,
-Graham
Thread: DVD Audio problems
The audio is probably AC3. Tmpgenc is not an authoring program, but an encoder. Tmpgenc DVD Author is what you need to look into. You can then attach the vobs you (add movie ?), create a menu, compile and burn.
Yep, use TMPGEnc DVD Author (30 day fully functional free trial), and after creating a new project, press the "Add DVD Video" button. Point it to your VIDEO_TS folder on your disc. If you only have one title on the disc then it will automatically load it up for you, otherwise it will ask you to select which title you want to import. Configure your menu, chapters etc etc to taste then output and burn.
If in doubt, Google it.
Audio problems after ripping DVD
By ksimz202 in forum Newbie / General discussionsReplies: 3Last Post: 28th Mar 2011, 01:49 -
Audio problems on my dvd
By leemorley in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2010, 03:55 -
audio problems when burning a DVD
By cosypete in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 18:23 -
dvd audio problems
By jchmbs in forum Authoring (DVD)Replies: 1Last Post: 24th Oct 2009, 08:33 -
DVD Audio Problems
By 557953 in forum Authoring (DVD)Replies: 7Last Post: 25th Jan 2008, 14:42
Statistics
Newest guides
Latest tool updates
New media comments
