VideoHelp.com Forum
    I have used DVD RB a few times to backup episode discs when the 1st SHRINK copy I have done looks ugly due to the fact that the Comp % is usually very high (50-60%).
    Is it possible to run VOBblanker + menu shrink on a disc prior to using DVD RB? This would remove certain extras so that the compression % needed would not be so high...
    I though I read that RB doesnt allow pre processing.
    I didnt want to do it, then run a 4 hour RB session, only to find that it doesnt like it..
    I have no idea what im doing, whatsoever.
  2. Member fritzi93's Avatar
    Yeah, go ahead, it always works for me.
    BTW, I just received an episode disc set as a gift, the DVD release of Michael Wood's "In Search of the Trojan War", from 1985. 3 hours worth each disc at 4:3 AR and those bastards at the BBC have to put trailers on the disc as well? Normally, I reauthor movies, but with the separate episodes and many chapters, the menus are actually useful. (They're still shots anyway, so I kept 'em). The upshot is, I decrypted, ran it through VobBlanker, then DVDRB two ways: Full D1 and Half D1. The Half D1 looked much better than Full D1, which had a lot of artifacts. You might try that if the running time is near three hours.
    Good luck.
    P.S. Oh, dunno about using Menushrink, whether DVDRB will like it or not.
    Pull! Bang! Darn!
  3. Member jeanl's Avatar
    menushrink and vobblanker should work fine as pre-processing before DVDRB. They both output very compliant DVDs, as attested by the number of people who've used both...
    jeanl
    MenuShrink a free tool to shrink menus into stills with or without audio!
    DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
    Haven't used menushrink, but for what it's worth the half dozen attempts to use vobblanker have never produced an output that can be loaded by DVD Shrink or DVD RB
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  5. Member jeanl's Avatar
    That is amazing! Certainly not the way it ought to be. If you point out these problems to jsoto, he will be very interested! Vobblanker was designed to create fully compliant DVDs, and I know that jsoto is a big fan of DVDRB, so I'm really surprised that you encountered such problems (I never did!)...
    jeanl
    Thanks for the advice guys.
    Gunslinger I have never had a prob with Vobblanker + shrink.
    JeanL, menushrink is awesome and keeps getting better, thankyou.
  7. Member jeanl's Avatar
    hey you're welcome!
    jeanl
  1. BD Rebuilder question
    By mobie29 in forum Blu-ray Ripping
    Last Post: 9th Jun 2011, 02:56
  2. BD Rebuilder question
    By fusion99 in forum Blu-ray Ripping
    Last Post: 30th Jul 2009, 09:56
  3. Noob DVD Rebuilder Question
    By peggypwr1 in forum Newbie / General discussions
    Last Post: 10th Dec 2008, 07:33
  4. question about using DVD Rebuilder to compress 4 dvds into 1
    By jimdagys in forum Newbie / General discussions
    Last Post: 7th Jan 2008, 13:15
  5. Replies: 1
    Last Post: 30th Oct 2007, 04:20
