ok, i use gspot to detect the framerate of the xvid/divx video, then use tmpgenc to encode into .m2v.
i'm having problems with every xvid that has a framerate of 23.976 fps. i use tmpgenc to convert, using "23.976 fps (internally 29.97 fps)", and "3:2 pulldown when playback".
the outputted m2v. has a slight "lag" every 5 seconds or so.
another method, i used tmpgenc to convert using "23.976 fps". and "non-interlace".
then i use dgpulldown to convert the fps from 23.976 to 29.97.
the outputted m2v still has a slight lag every 5 seconds or so.
any xvid/divx that has a detected framerate of 29.97 turns out fine when converted with tmpgenc at 29.97 fps, non-interlace.
is there anyway to convert 23.976 fps xvids to .m2v without that lag?
What happens if you use 23.976 (not with internal 29.97) and check "do not frame rate conversion" and do NOT check "3:2 pulldown." Then insert the pulldown flag after it is encoded. (DVD-Lab will do this, pulldown.exe and others as well)
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 17:57 -
Problems with DVDFab when converting DVD TV episodes to Xvid
By ryangarfield in forum DVD RippingReplies: 3Last Post: 11th Oct 2009, 10:38 -
Framerate glitch after converting AVI to DVD. Any ideas?
By toasterkat in forum MacReplies: 5Last Post: 14th Dec 2007, 18:25 -
Having framerate issues converting to DVD
By MikeCouves in forum ffmpegX general discussionReplies: 17Last Post: 4th Oct 2007, 20:17
Statistics
Newest guides
Latest tool updates
New media comments
