I just started using ffmpegX very recently. I encounter a problem when I try to convert Quicktime MOV files (mostly trailers and such) to AVI XviD, there is no sound when I try to play the MOV file in ffmpegX and no sound after the file is converted. Video plays and converts successfully, just no audio. I am able to successfully convert other files (like AVI to AVI XviD). Any suggestions?
Results 1 to 17 of 17
Nice! That worked really well with the Cars trailer. Thanks!Originally Posted by major
I have a follow-up question though, I tried converting another trailer (Harry Potter & The Goblet of Fire), and it produced 2 files, an AVI video file without any audio and an empty (0KB) MP3 file. I tried changing audio to AAC and same thing happened, it produced an AVI video file and an empty AAC file.
Anyway, will definitely be registering ffmpegX. -
I also am having problems with encoding from .mov to anything else. I even downloaded the trailer mentioned in the previous post and used the audio track settings and framerate as suggested but no joy.Originally Posted by Penguin45
If I drag the resultant file into the source panel it says no audio!
Any other things I can try?
Don
Mac OSX 10.4 on a Dual G5 2.3Ghz -
Re previous post, heres the output file if it helps. I've deleted hundreds of duplicate frame messages as indicated.
Encoding started on Fri Sep 2 14:00:56 BST 2005
MEncoder dev-CVS-050814-13:46-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x14f7ce1
ISO: File Type Major Brand: Original QuickTime
MOV: selected audio stream (2) does not exists
Quicktime/MOV file format detected.
MOV track #0: 452 chunks, 2727 samples
MOV: Found unknown movie atom SMI (21)!
Image size: 480 x 192 (24 bpp)
Display size: 480 x 192
Fourcc: 3QVS Codec: 'Sorenson Video 3'
MOV track #1: 228 chunks, 0 samples
Audio bits: 16 chans: 2 rate: 44100
Audio extra header: len=76 fcc=0x77617665
MOV: Found unknown audio atom Ä>Fourcc: U
MOV: longest streams: A: #1 (228 samples) V: #0 (2727 samples)
VIDEO: [3QVS] 480x192 24bpp 24.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x33515653 size:480x192 fps:24.00 ftime:=0.0417
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=480 h=192]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffsvq3] vfm:ffmpeg (FFmpeg Sorenson Video v3 (SVQ3))
Forcing output fourcc to 58564944 [XVID]
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
VDec: vo config request - 480 x 192 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
videocodec: libavcodec (480x192 fourcc=58564944 [XVID])
About 30 messages like this
1 duplicate frame(s)!
( 0%) 0fps Trem: 0min 0mb A-V:0.000 [49:0]
0min 0mb A-V:0.000 [47:0]
00 [46:0]
About 500 messages like this
2688f ( 0%) 218fps Trem: 0min 0mb A-V:0.000 [753:0]
Flushing video frames
Writing AVI index...
Fixing AVI header...
Video stream: 751.786 kbit/s (93973 bps) size: 10667239 bytes 113.514 secs 2725 frames
Encoding completed on Fri Sep 2 14:01:08 BST 2005 -
Hmm...I just checked and I'm using 0.0.9t (0.0.9t) released on the 27th August. What does the r2 signify? Is there another release?Originally Posted by Penguin45
Don -
It is a bugfix release. By doing apple-I on the application icon you can see if it is r2 or not. If it is not, download it again from http://homepage.mac.com/major4/ffmpegX.dmg (no need to install again the binaries, just overwrite the application).
Thanks for the rapid responses!
Yes, I just checked and its definately r2
What else could be causing this?
Cheers
Don
PS
This bit looks very suspect in the output log:
Although the trailer plays perfectly before encoding? -
Try to export the audio as WAV with Quicktime Player, and add the WAV file in "Add audio.." in the audio tab, or remux it to your silent AVI with the "Mux" tool (Mux as.. AVI).
major
I just re-installed the binaries and that fixed the problems with the trailer!
I've now tried to encode a H264 mov file which I made using Quicktime pro. The video is being encoded fine but the resultant .avi is without an audio track. I've tried changing the audio track in FF but no joy. Heres the 1st part of the output file:
Encoding started on Fri Sep 2 17:00:00 BST 2005
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x76f613
MOV: selected audio stream (1) does not exists
Compressed header uses zlib algo!
Compressed header size: 34219 / 90767
MOV track #0: 1509 chunks, 8122 samples
Audio bits: 16 chans: 2 rate: 22050
Audio extra header: len=91 fcc=0x77617665
MOV: Found MPEG4 audio Elementary Stream Descriptor atom (51)!
Fourcc: a4pm
MOV track #1: 1886 chunks, 1887 samples
MOV: Found unknown movie atom colr (18)!
MOV: AVC decoder configuration record atom (43)!
Image size: 1024 x 768 (24 bpp)
Display size: 1024 x 768
Fourcc: 1cva Codec: 'H.264'
MOV: longest streams: A: #0 (8122 samples) V: #1 (1887 samples)
VIDEO: [1cva] 1024x768 24bpp 5.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x31637661 size:1024x768 fps: 5.00 ftime:=0.2000
Opening video filter: [scale w=1024 h=768]
Selected video codec: [ffh264] vfm:ffmpeg (FFmpeg H.264)
VDec: vo config request - 1024 x 768 (preferred csp: Planar YV12)
videocodec: libavcodec (1024x768 fourcc=58564944 [XVID])
Add an 2 video/Audio tracks to a .mov file without using Quicktime
By thomas31388 in forum Video ConversionReplies: 0Last Post: 24th Sep 2008, 15:35 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 18:42 -
Is it possible to split the Audio and Video from a Quicktime .mov file.
By StuartB4 in forum Video ConversionReplies: 6Last Post: 12th Jan 2008, 21:02 -
trouble converting Quicktime mov. to avi (on windows XP)
By pifkel in forum Video ConversionReplies: 3Last Post: 31st Dec 2007, 04:19 -
Suggestion for converting hundreds of mov quicktime files
By m021478 in forum Video ConversionReplies: 0Last Post: 15th Aug 2007, 15:16
