VideoHelp.com Forum
  1. when i capture from my dv camera i get a bunch of small clips.is there any settings i can change to get just one big avi file? i cant find anything in the options tab to change this. thanks.
  2. Member edDV's Avatar
    Sure. Tell us which program you use to capture.
    http://www.kiva.org/about
  3. sony vegas.its in the subject.
    You probably have the capture utility set to create individual clips for each scene change. Check it and undo it. I prefer the individual clops myself.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  5. Member edDV's Avatar
    Turn off scene change
    DV metadata includes timecodes for when you started and stopped your camcorder. In that mode you divide clips by that data.
    If you can't find it in the preference menus I'll look later.
  1. Replies: 8
    Last Post: 19th Jan 2010, 20:46
  2. Another Sony Vegas Pro question.
    By ingeborgdot in forum Editing
    Last Post: 9th Dec 2009, 12:42
  3. Sony Vegas 8 Pro question
    Last Post: 30th Nov 2009, 16:59
  4. Sony Vegas 8 Pro question
    Last Post: 7th Sep 2008, 00:09
  5. Sony Vegas Question
    By ChristianPaprika in forum Newbie / General discussions
    Last Post: 29th Aug 2007, 22:46
