A friend of mine told me that XSVCD was a variable bit rate SVCD. The way he explained it was when there was a need the bitrate would jump up to the specified max and decend as well when needed. This way you could have high quality with the best size possible.
Looking around I see that XSVCD has many high bitrates to choose from but the bitrates are constant. Am I missing something?
Thread: Meaning of XSVCD
Check the "What Is" guides on your left for clarification of these terms.
XSVCD does not necessarily mean variable bitrate encoding. Both regular SVCD and XSVCD can use either constant or variable bitrate.
XSVCD simply means any variation of SVCD outside of the official standard specifications. The standard includes cbr or vbr mpeg-2 up to 2600Kbs, mpeg-1 layer 1 or 2 audio from 32 to 384Kbs, and resolution of 480x480 for NTSC or 480x576 for PAL video.
XSVCD for example might have higher bitrate such as 3500Kbs, or non-standard resolution like 720x480 or 352x480 or even 352x240. The reasons for doing this are usually to obtain better quality, or to fit more minutes of video on a cd-r. However compatibility of XSVCD and XVCD with your DVD player is not guaranteed so you need to experiment and check the DVD Player guides on this site.
the meaning of various tunings in x264
By codemaster in forum Video ConversionReplies: 2Last Post: 15th Mar 2012, 09:49 -
Meaning of error message presneted by eac3to
By Mr Davo in forum Blu-ray RippingReplies: 0Last Post: 6th Feb 2011, 23:55 -
what is the meaning of these ? frame based, lower & upper field first.
By khalid81 in forum EditingReplies: 3Last Post: 15th Jun 2009, 11:27 -
Best way (meaning quality and 700MB size) to convert a DVD to a Xvid?
By riahc3 in forum DVD RippingReplies: 24Last Post: 7th Jun 2009, 16:59 -
U.K. to give new meaning to "Big Brother" is watching
By aedipuss in forum ComputerReplies: 11Last Post: 18th Oct 2008, 09:00
Statistics
Newest guides
Latest tool updates
New media comments
