VideoHelp.com Forum
Results 1 to 11 of 11
    NEC-1300A writer FW 1.08 XP SP2. Burnsoftware Nero 6+
    Whilst preparing for burning I get a power cailibration error.
    What to do??
    sorry for being human,
    it appears NOT to be a common mistake
  2. Member NoFace's Avatar
    are you running two drives on your comp? I had the same prob with a NEC CD burner and then adding a dvd-rom drive to a Dell tower. In the end I replaced the CD drive with something else, and it solved the problem. It'd be interesting to hear if someone else solved this without replacement, so I could be pissed about how I didn't really need to spend the money.
    occasionally larger than 255 characters
  3. Had same problem with Sony burner and Nero. It was my media. What discs are you using?
    I indeeed have 2 drives 1 rom only and one cd/dvd writer. The funny thing is that with cd burning there are no problems. This media I have been using for quite some time now w/out any rpoblems.
  5. Could possibly be your media and could possibly be your laser lens becoming dirty. Had this happen to me on a Pioneer drive and blew it out with canned air. Symptoms were the same as yours in that CD's burned fine but DVD's wouldn't.
  6. Member inuyasha's Avatar
    my nec 3500 did that. cleaned with cd cleaner.. the type that has a little brush mounted on a DVD. works fine after.
  7. VH Veteran jimmalenko's Avatar
    It's generally media that causes this.
    Forum search or google search should give more info.
    If in doubt, Google it.
  8. Man of Steel freebird73717's Avatar
    Have you recently updated your firmware? I have hade bad firmware updates give me that problem.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
    What to do??
    As others have said, it's usually crappy DVD media that causes this.
    A way that sometimes helps to prove this is to lower the burn speed.
    Say you have media rated at 4X that gives you this error consistently. Try burning at 2X or 1X. If it burns at lower speeds fine, but at the rated speed, it consistently gives this error, then the diagnosis of crappy media is pretty much confirmed.
  10. i had the same problem, i just don't use cd's in the drive dvd only, it seems when i change types thats when this happens(strange i know) also i went in to admin of XP and disabled the cd drive burning element(not sure whats its called) but if you search on the issue you will find it, since 3 weeks ago i have not had one issue since(knock on wood)
  11. Come on, search the forum, there are like thousands of posts on PCEs...
  1. VOB Error While Using Power DVD 10
    By skorpinok in forum DVD Ripping
    Last Post: 24th Aug 2010, 14:27
  2. Imgburn - Power Calibration Error message
    By concisa in forum Authoring (DVD)
    Last Post: 12th Nov 2009, 15:39
  3. Power Calibration Area Error
    By zork152 in forum DVD & Blu-ray Writers
    Last Post: 20th Jul 2009, 17:27
  4. JVC HDD Camcorder/Cyberlink power director file import error
    By lonewolf_mb in forum Newbie / General discussions
    Last Post: 29th Dec 2008, 21:53
  5. Nero's "Power Calibration Error" fix.
    By AlecWest in forum Newbie / General discussions
    Last Post: 8th May 2007, 19:26
