hi all
we're using ffmpeg to convert 3gp videos taken from phones to mp4s and wmv's
we're having a problem with the output videos playing faster than the original
eg. the 3gp video goes for 4 seconds
but the mp4 file goes for 3 seconds
all the footage is there, it just plays faster
if it helps, here is the command line
ffmpeg -i $srcFile -s qcif -b 96 -ar 8000 -ab 16 -vcodec mpeg4 $destFile
i will add the output string in a couple of minutes
has anyone experienced something like this before using ffmpeg or other programs (on linux or windows)?Code:Input #0, mov,mp4,m4a,3gp, from '/videos/srcfile.3gp': Duration: 00:02:54.5, start: 0.000000, bitrate: 3 kb/s Stream #0.0: Video: h263, 176x144, 12.60 fps Stream #0.1: Audio: amr_nb, 8000 Hz, mono Output #0, mp4, to '/videos/destFile.mp4': Stream #0.0: Video: mpeg4, 176x144, 12.60 fps, q=2-31, 96 kb/s Stream #0.1: Audio: aac, 8000 Hz, mono, 16 kb/s Stream mapping: Stream #0.0 -> #0.0 Stream #0.1 -> #0.1 Press [q] to stop encoding frame= 48 q=0.0 Lsize= 97kB time=3.8 bitrate= 208.4kbits/s video:77kB audio:17kB global headers:0kB muxing overhead 2.132194%
i'm using an ffmpeg rpm downloaded from dag.wieers.net
which i recompiled to add amr_nb support for 3gp audio decoding
i've worked out that the audio stream is at the right speed
but the video stream finishes well before
thanks
dave
Results 1 to 1 of 1
3gp -> mp4/wmv audio problem
By dragonBoy in forum LinuxReplies: 1Last Post: 7th Sep 2010, 16:08 -
Converting DV to 3GP --> Output Looks Rather Blocky & "Pixelate
By SnakeGirl in forum ffmpegX general discussionReplies: 8Last Post: 21st Jan 2008, 05:13 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 07:02
