When i create a Video_ts with Svcd2dvd 2.0 it works fine, but if I use TMPGEnc DVD Author and want to use the add dvd video option and go to a video_ts created with svcd2dvd 2.0 it does not show up inthe box (i.e. it is blank where you normally see the title for selection) any ideas why?
"Video_TS" what? Video_TS folder, Video.TS.IFO?Originally Posted by Scorp121z
When you use the add DVD video option you don't get an option to add a specific file- you just open the video_ts folder. Or you can even select the folder that contains the video_ts folder.
TMPGENC DVD Author Divx - Cannot import .srt subtitle files - how to do it
By wa5dxp in forum Authoring (DVD)Replies: 20Last Post: 26th Oct 2010, 10:45 -
DVD menu software to import into TMPGEnc Authoring Works 4
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 28th May 2010, 13:34 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
TMPGEnc DVD Author 3 can't import AVI video, only audio?
By XyBeRz in forum Authoring (DVD)Replies: 7Last Post: 31st Jan 2009, 09:54 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
Statistics
Newest guides
Latest tool updates
New media comments
