I have downloaded a video in 2 files combined them togerther in virtual dub and then used vso divx to dvd to make it dvd compatable. When converted burned to dvd and when playing in a standalone player I get this disc is not compatable in this region. Any fixes or ways around this problem. Thanx Al.
I reject your reality
and substitute my own.
- Adam Savage -
- Mythbusters -
It will be a PAL/NTSC problem - most likely you downloaded PAL files, and your player cannot play PAL. The fix is to convert to NTSC, or get a multisystem-capable player.
If in doubt, Google it.
what software would convert pal to ntsc
- Adam Savage -
- Mythbusters -
any encoding software can do it. It's been done to death in the forums - do a search. There's also a number of guides in the Guides section.
DivxtoDVD can do it for you. There is an option for botht he TV system (format) and aspect ratio. By default these are set to auto, so PAL goes in then PAL comes out. Just change Auto to NTSC from the drop down and away you go.
Authoring from downloaded video files ...
By deepcut in forum Authoring (DVD)Replies: 13Last Post: 28th Nov 2011, 06:07 -
Protect Video Files From Being Downloaded (FLV)
By foochuck in forum Video StreamingReplies: 1Last Post: 12th Oct 2009, 14:06 -
Is there a way to remove watermarks from downloaded video files?
By f-zer0 in forum Authoring (DVD)Replies: 3Last Post: 1st Feb 2008, 17:19 -
downloaded video files doing strange things
By ouiglz in forum Newbie / General discussionsReplies: 6Last Post: 26th Jan 2008, 14:37 -
Codec problems with downloaded avi files?
By aelfheah in forum Video ConversionReplies: 3Last Post: 16th Jun 2007, 07:48
