Results 1 to 9 of 9
    Nov 2003
    Kalmar, Sweden
    Please help me, I have a Sony dvp-ns405 dvd-player and I was trying to burn an IMG-file to a dvd. I started out with a DVD-R(dash) disk and when I placed the disk in my dvdplayer it said that the disk was "dirty". I read on a forum that I should try a DVD-R (plus) disk instead, I did that but it says the same thing. I've tried to burn with Nero 6 Ultra and DVD-Encrypter but nothing works.
    What should i do, any suggestions?
  2. Preservationist davideck's Avatar
    Feb 2003
    USA
    My Sony DVD changer gives me a disc dirty error whenever I author a DVD beyond about 4.2 GB. I know it sounds weird, but if I stay below 4.2 GB I never have a problem... It took a while to figure this out!
    None of my other DVD players have this problem.
    Nov 2003
    Kalmar, Sweden
    Ok, so there is really nothing i can do to solve this problem? I forgot to say that the disk doesn't work on my computer either, sure i can watch the vob-files in VLC-media player but thats it. My computer doesn't recognize the disk as a dvd it seems.
    *EDIT* Can it be that the img is damaged or something? could that give my error message
    Apr 2003
    my computer, where else?
    what was the media rated burn speed? did you possible forget to set the
    burn speed within the media's limit when you burned it? just a thought.
    i've done it a couple of times with the resulting coasters.
    I said I'll be done in a minute. I meant a Microsoft minute.
    Nov 2003
    Kalmar, Sweden
    The dvd are Platinum 8x and my burner is a NEC ND-3520A with max burn speed at 8x, so it can't be that :'(
    More suggestions please
    Nov 2003
    Kalmar, Sweden
    Ok, i tried to burn a diffrent IMG. Success! hahaha marvelous Anyhow, it must have been the other IMG that was somehow messed up or something cause now it works.
    Thanks to all of you who answered and tried to help out.
    Nov 2003
    Kalmar, Sweden
    Damn, one hour in the movie that cursed message appered again "The disk is dirty". Im getting pretty tired of this. Anyone have any other suggestions?
  8. as for now, get used to it. Try & find a rut man, (media, rip * burns) that runs smooth & works GREAT for your player.
    Nov 2003
    Kalmar, Sweden
    So its acctually a matter of trial & error then?
