VideoHelp.com Forum
  1. I've recently been converting a bunch of OGM files to AVI and further trying to use ffmpegx to convert the AVI files to DVD (mpeg2enc) in order to import the resulting files to DVDSP3. Everything converts as it's supposed to, however no matter what I try, I can't seem to get DVDSP to import the resulting m2v file. I've tried simply importing the m2v right into DVDSP as an asset, and I've run the m2v through ffmpegx to create a 3:2 pulldown menu but DVDSP still won't import the video. Is there anything I'm forgetting to check off or uncheck in ffmpegx? Any help would be appreciated.
  2. Which framerate and encoding options did use?
  1. mpeg2enc.
    By zaque2004 in forum ffmpegX general discussion
    Last Post: 21st Sep 2011, 04:35
  2. Problems Encoding DVD with mpeg2enc
    By justin35 in forum ffmpegX bugs and suggestions
    Last Post: 11th Nov 2009, 14:07
  3. Avi to DVD (mpeg2enc), doesn't fit screen (noob)
    By bilboshaggins in forum ffmpegX general discussion
    Last Post: 14th Dec 2008, 14:53
  4. Crash in 0.0.9y converting AVI to DVD using mpeg2enc profile
    By mainframer in forum ffmpegX bugs and suggestions
    Last Post: 20th May 2008, 01:05
  5. Problems w/selectable subs avi-DVD w/mpeg2enc
    By kenzo69 in forum ffmpegX general discussion
    Last Post: 20th May 2007, 05:53
