Results 1 to 18 of 18
  1. Hello
    I want to know how can I connect internet through a command on the command line?
    I have Windows XP.
  2. Member studtrooper's Avatar
    May 2004
    The Beyond Section
    Connect to the internet or surf the internet? If you have broadband, you're technically already connected. If you have dial-up, I think you are SOL from connecting in DOS. Why would you want to do this? Pinging purposes?
    Your base? Well, they belong to me now...
  3. I mean connect the intenet.
    I want this command beacause I want to save it as a BAT file and put the file in the startup. so the computer will automaticlly connect the internet.
  4. Member studtrooper's Avatar
    May 2004
    The Beyond Section
    Via Dial-Up I assume?
  5. Yep - Dial Up
    Dec 2003
    Just copy the dialup shortcut to your Startup folder and tell it to connect automatically.
  7. Originally Posted by Silvas
    I tried it - didn't work
    it will work..you have to go into the settings of your dial-up connection and tell it to save your password and not prompt for name-password...do some poking around with the settings in your dial-up connection and you will find it.
  9. It didn't work too - I tried it before.
    Do you know if there is a command to connect the internet?
  10. EC. Learn from what the people here are telling you. It does work. And there is no command line command for what you are asking.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  11. Member otpw1's Avatar
    Jan 2005
    midwest USA
    That's the way I used to do it with 98se and ME.
    A good divorce beats a bad marriage.
    Now I have two anniversaries I celebrate!
    Jul 2002
    Up in yo' bitch.
    Yes, it does work. You have to go in the connection properties and uncheck all of those little boxes that relate to prompting and confirmation. The only setting I left checked was redial.
  13. When I open IE, it automaticlly connect the internet.
    But when I open FireFox, it dosen't work.
    Mar 2003
    Canada
    Actually there is a command for what you want. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/rasdial.mspx
    I use it for DSL, but it should work for dial-up too.
  15. thanks, but I got an error when I try to connect through this command.
    I typed:
    rasdial "xxx xxx xxx" username password|mypassword /domain:xxx.xxx.xxx
    with no successful.
    Mar 2003
    Canada
    I have mine setup like this
    rasdial connectionName "myUsername" "myPassword"
