hello all i'm new to this scene so please be gentle.
Here's my problem i have a movie in avi format i used dvd santa to convert it to dvd which it did fine,but when i play the movie in my dvd player (TV) the movie will not fast forward even tho it says it's fast forwarding at 2x, then when i hit play on the controller it's at the end of the movie.It will rewind fine but i can't cut to scenes and so on what am i doing wrong? Also i used nero to burn the dvd.
Thxs.
Using DVD Santa and probably cheap media.what am i doing wrong?
thxs for no help at all.Originally Posted by guns1inger
He was helping you.. he was telling you the two main reasons why your project doesn't work...You asked, he explained...
Read between the lines ...Originally Posted by showoff
DVDSanta is more than likely the thing you did wrong. It is crapware on the most part, as are quite a few of the all-in-wonderful-1-click-clueless-noob softwares that are out there. DivXToDVD is probably the best one I've seen, but it still doesn't compare to doing it properly - using a dedicated encoder and authorer.
This hobby ain't easy - you take shortcuts and you'll get the results you deserve
If in doubt, Google it.
i noticed the same thing with dvdsanta the other day
as home vid was only 12 minutes not really a big deal
the TDK TTG02 8x dvd-r i use seems pretty good media
works fine in all the drives iv tried it in including an old Playstation 2 and a new slim playstation 2 which are supposedly picky
the file fast forwards fine when playing back on pc
im sure ill start using a better converter soon
maybe tmpeg to encode and tmpegdvd to author
need to do some reading on it
was forced to try an all in one (dvdsanta) as i needed the disk quickly to take out with me
will give it credit in that the picture was good and it was quick
copying DV AVI to hard drive
installing dvd santa and encoding
burning with nero
only took 30 minutes to have a finished fully working dvd
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Getting My Hiphop Show ON DVD From AVI To DvD Fast? NEED HELP
By dbztoolkit in forum Authoring (DVD)Replies: 2Last Post: 20th Nov 2009, 07:33 -
Fast Foward / Rewind xvid or mpg?
By fredfillis in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 04:06 -
files to big/or sound to fast
By silvabak in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2008, 11:17 -
DVD- AVI: Video too fast
By HHBear in forum DVD RippingReplies: 1Last Post: 14th Jul 2008, 19:41
