Results 1 to 24 of 24
  1. Hi, How to open .MP4 files in virtualdub? it says file is not supported or something.. i hope there's a plugin that allows me to open .mp4 files
    The reason i want to open it in virtualdub is so that i can run a sharpen filter for the mp4 video. this is so tahti can watch on my PSP.
    i figured tha ti can convert the mp4 to avi then sharpen, but it would lose alot of quality that way.
    thanks
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You can use AVIcodec or Gspot and drop the file into them. This will tell you the codec needed. You check on video codecs in the 'Tools' section to the left and install it, and VD should be able to open it. You will have to re-encode if you use the filters, but with care the quality lose can be minimal.
  3. Use this program. http://sourceforge.net/projects/mp4cam2avi/ It changes the file to avi (no recompression, just telling the player how to handle it) so that VDub can recognize it. Use the batch (many to many) option.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    Just for information: MPEG-4 comes in many 'flavors'. It can be Quicktime, DivX, Xvid, 3ivX and a few more. The audio can also have several formats, MP3, Oog, AC3, PCM, and others. The best way to find out what you have and what codec is needed to open it is Gspot, AVIcodec or similar programs.
    For mp4 it doesn't matter if it is quicktime, DivX, XviD, 3ivX, etc. it is all just stored as native MPEG4 video and are all treated just the same.
    ogg vorbis, AC3, etc. would need to be stored as private streams as they are not part of mp4 specs.
  6. None of the above mentioned methods work, by the way.
    Even if you have the necessary codecs installed, vdub will not open it.
    Get an MP4 (container) source filter and use a recent VirtualDub. See the last post on this page:
    http://forums.virtualdub.org/index.p...t=14639&st=105
    And a direct link:
    http://www.tateu.net/software/dl.php?f=qtvd_bin
  8. Always Watching guns1inger's Avatar
    AVI Demux
    Read my blog here.
  9. Originally Posted by jagabo
    And a direct link:
    Wow, thanks. Terrific! Very happy with this.
    mp4/x264 are extremely popular in my surroundings, and I hated having to mess with mp4box time and again.
    Does anyone know if they above solution works with virtualbud 1.8.6.
    I have downloaded that source filter and installed it like this " Quicktime.vdplugin" should go in your plugins32 folder and "Quicktime.ini" should go in the VirtualDub root folder. Now when i open a video.mp4 i get the message .... unable to initialize quicktime: Initializeqtml. Can anyone tell me where the plugin32 folder should be located. Should that be in the root of the folder or in the plugins folder?
    http://forum.videohelp.com/topic348265.html
    directshow plugin for virtualdubwhich lets you load anything as long as you have splitters/codecs necessary to play the file in windows media player.
    the qt plugin does not work with all mp4 files.
    Oh great.. thanks for the tip MGH much appreciated going to try it out right away!
  13. Hello theres this problem driving me nuts :
    I cant find a way to open mp4 files in virtualdub.
    Tried anything i could find in these forums, but nothing works.
    Have input plugins installed in virtualdub (directshow, quicktime etc)
    Also all necessary codecs are installed like H264 etc
    The file plays fine in any mediaplayer, opening in vdub doesnt work
    properly, but when playing the video in vdub, it *does*show fine although any exporting/conversion results in
    grey, skewed distorted picture.
    Also, the "ask for extended options" never shows up when selected before opening a file...
    Any help would be highly appreciated ofcourse
    this is how it looks when playing in vdub, as it should bethis is how it looks when vdub does not play, or after conversion/exportgspot report of the mp4 file
    Possibly because of the file dimensions - 470*360. 470 is not divisible by 4, causes problems in some decoders.
    Not sure how to fix it.
  15. crop to a divisible by 4 ?
    See this thread from a year ago. It's one I opened regarding a similar tearing problem.
    In the thread it was noticed that the FFDShow H.264 decoder could handle the video properly,
    while CoreAVC was causing the tearing.
    Try disabling the DIVX H.264 decoder, and enable H264 in FFDshow
    http://forum.videohelp.com/threads/3...hlight=coreavc
  17. Member Innomen's Avatar
    Ok I guess I'm just not seeing the consensus here but would someone be willing to tell me how to get virtual dub to open mp4 files? (without linking to somewhere else, preferably)
    I have tried a variety of plugins, and I guess I am not using them properly.
    This is the file in question from Mediainfo.
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 54.7 MiB
    Duration : 7mn 9s
    Overall bit rate : 1 069 Kbps
    Tagged date : UTC 2010-10-29 01:14:14
    Video
    Format : AVC
    Format profile : Baseline@L3.0
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Muxing mode : Container profile=Baseline@2.2
    Codec ID : avc1
    Duration : 7mn 9s
    Bit rate mode : Variable
    Bit rate : 1 000 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 24.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.136
    Stream size : 51.2 MiB (94%)
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 7mn 9s
    Bit rate : 64.2 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 3.28 MiB (6%)
    Windows media plays the file fine, direct show input driver will not open it. Nor will anything else.
  18. Member
    You need the directshow Vdub plugin (mentioned above), H264 decoder on your system (coreavc OR ffdshow OR divx h264 decoder),
    and perhaps Haali media splitter.
    In Virtualdub select file/open. Select the file, and in "files of type" select the directshow plugin.
  19. Member Innomen's Avatar
    That's insufficient, I don't want options I want a confirmed working path. I have ffdshow tryouts x64, the direct show plugin and the proper codecs (the files play in wmp). Still, the file in question will not open.
    Is there a working alternative to virtualdub?
    If you want something that works consistently regardless of various system installed filters/codec, load your files with avisynth into virtualdub using ffmpegsource2
    avidemux is another alternative to vdub
    Thanks for the Avidemux link. Worked perfectly for me. Kept getting dropped audio and also had to convert to MPEG-I to allow files to be edited in VDub: this allows opening of any file I have (so far)!
    Much appreciated.
    TH
    "I've learned that life is one crushing defeat after another, until you just wish Flanders was dead!" --- Homer J. Simpson
  22. Member
    That works here. Thank You
  23. EDIT: Actually installing recent x264VfW from http://www.free-codecs.com/x264_VfW_download.htm doesn't work for me:
    Need to convert to AVI but it seems to preserve quality:
    (thanks for advice)
    Last edited by stefek99; 8th May 2012 at 04:43. Reason: checked resolution and didn't work for me
  24. Originally Posted by bayme View Post
    And a direct link:
    Can this program be made to select mp4 files? My virtualdub WILL process them.
    Thanks,
    Joe
