Sorry but this is going to require a long explanation. I hope someone will have the patience to read all this and give some advice.
I’ve prepared a movie which is too large for a DVD5 disc. I decided it was time to use a DVD9 but can’t get it to burn. I put the Dual Layer disc in the burner (BENQ DVD DD DW1620) and started CopyToDVD the same way I’ve always done with the DVD5 discs.
This is what I see on the CopyToDVD Manager window:
Then I click on the Write button. For a few seconds it says it is writing and then suddenly I get this error message:
Can anyone tell me what this error means?
I decided to use another method so I output an ISO file with ImgTool Classic and then tried burning that with DVD Decryptor. When I switched DVD Decryptor’s Mode to ISO > Write I got this dialog box:
Maybe the information on the right can tell someone what the problem is.
This is a shot of the same box with the info box showing text further down:
Another shot with the rest of the information:
When I selected the file to write and hit the Write button I got this error box:
Any idea what this error is?
This is the top portion of the DVD Decryptor log:
This is the rest of the log:
Can anyone tell me what I’m doing wrong? Do the error boxes tell you anything? I’ve used 3 discs trying to get this to work and I don’t even know if I’ve made coasters of them or if they are still good. How can I tell? If I understand the information box in DVD Decryptor the discs are empty and still usable. Is this true? Would very much appreciate any help with this.
Thanks a lot,
.....Gord
Thanks to ImageShack for Free Image Hosting
Results 1 to 13 of 13
Thread: Trouble burning Dual Layer discs
Outside a dog a book is man's best friend. Inside a dog it's too dark to read.
------------ Groucho Marx
First of all,
Get rid of the crappy discs. Verbatim makes error free dual layer discs in my experience. Go with those and see if you have the same problem. If you do, then you can at least rule out the discs.
It might be worth while changing firmware for your burner.Compatability issues with ritek D01 discs are upgraded with modified firmware on some burners.
Try cd club freaks.bmiller,ont.canada
I burned dual layter disc before, but i used Nero one and it work fine, and alway check the speed compability.
If the size of your project is only 4.87 GB, then just use dvdshrink to resize it. Dual layer disks are too expensive to waste all that space.
TANSTAAFL
The discs were sold under the Memorex brand name and I've never hadOriginally Posted by slacker
any trouble at all with the DVD5 discs they sell.
Also, they are the only brand available in my area. I'm in a small city and there isn't a great deal of choice.
Thanks again to ImageShack for Free Image Hosting
I'll try that. Thanks.Originally Posted by bmiller
I agree and it worked fine with DVDShrink but the project is not finished and when it is it will be much larger. I just wanted to see if I'd have trouble with dual layer discs. I did (obviously) and now I just want to know what to do to correct the problem.Originally Posted by dantruon
Thanks, all of you, for the input. I'll see if there is a new firmware and get back with the results.
In the meantime does anyone else have any insight to offer? Also, nobody said whether the error reports categorically tell whether the discs are still good or have gone to Coaster Hell. Anyone?
.....GordOutside a dog a book is man's best friend. Inside a dog it's too dark to read.
Updated the firmware and it made no difference.
Still looking for any assistance if anyone can help.
that discs already been used,bin it,either you or one of your programmes has written to it already.
also,update dvddrcrypter to the last ,latest version 3.5.4.0. and do the same with copytodvd.
newer firmwares for your drive are here:
http://dvdpro.club.st/firmware/BENQ_FW.htm
also,when you burn a dual layer disc,you may want to use the book type manager disc ya got with yer drive to change the booktype to dvd-rom,or get it here:
http://support.benq.com/front/BenqMa...otId=undefinedLifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
Thanks again to everybody for helping. Turns out the problem was the discs. I tracked down a Verbatim disk and it worked right away.
Glad to hear you sorted it out.
I just wanted to commend you on the detail you went into in the first post - niiiice
If in doubt, Google it.
Here is a link to modified firmware and flashers for benq drives.The latest ones will give support to ritek d01 discs.
I flashed my nec 3540 for ritek support and so far no coasters with memorex or ritek d01 unbranded.bmiller,ont.canada
Thanks!!Originally Posted by jimmalenko
I hate trying to read posts from people without enough information. I do try to be thorough enough to be understood. I appreciate your noticing.
Thank you. Unless I'm blind you forgot to put the link in your message. I would sure appreciate getting that.Originally Posted by bmiller
Thanks again, guys.
You're right,here is the link
Too early in the morning,not enough coffee.bmiller,ont.canada
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Burning to dual Layer discs
By Mastablastacious in forum DVD RippingReplies: 19Last Post: 5th Feb 2008, 18:50 -
Having trouble with dual layer discs
By red69 in forum Authoring (DVD)Replies: 6Last Post: 8th Sep 2007, 04:16 -
Getting I/O Errors While Burning Dual Layer Discs
By VanCity in forum Newbie / General discussionsReplies: 5Last Post: 31st May 2007, 23:35
