Thread: burning subtitles
To burn the subtitles, use "DVD mpeg2enc" and "Decode with mplayer".
Ok, thanks, but next to VOB subtitles, I am able to select a number (0 until 31), what do I have to select?
And about the audio, do I choose mp2 or mp3?
last question? What do I select in sizzle as title?
Greetings
SilentMac
Select a number then click PLAY to see if it is the good subtitle, if not, select the following number until you find it. For audio, choose mp2. In Sizzle you may select the m2v file or the mpg file.
Thanks, but what do you mean 'click PLAY to see if it is the good subtitle'?
In the preview or after decoding?
greetings
SilentMac
In the preview, before encoding.
Ok thanks, it works!
last question: about Sizzle, do I select the mpeg as a title without selecting mp2 as audio or do I have to select audio to also?
Greetings
SilentMac
Burning movies with subtitles?
By legenderycity in forum Authoring (DVD)Replies: 9Last Post: 29th Jan 2010, 08:32 -
Burning subtitles to video
By nikitar in forum ffmpegX general discussionReplies: 2Last Post: 4th Oct 2009, 18:02 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
how to remove subtitles before burning to DVD
By ouiglz in forum SubtitleReplies: 5Last Post: 20th Jan 2008, 08:31 -
Subtitles and codecs for burning
By vipertongn in forum SubtitleReplies: 0Last Post: 17th Aug 2007, 17:23
