VideoHelp.com Forum
  1. I use Virtual DUb to capture Mpeg4, or I use VirtualDub to convert avi files to mpeg4. When I put it on a Dvd and watch it on a Dvd DivX Player, the video comes out all jerky. However divx files I download off the internet, play good. It's just the one's I create.
    What settings do you use in VirtualDub?
  2. Renegade gll99's Avatar
    People must be tired of answering this so that is probably why you had to bump 3 days later.
    I use a bitrate of about 1800 or less and mp3 audio. No gmc or Quarterpixel.
    I also use any old framesize but usually 640x480.
    What settings do you use and which version of the divx codec?
  3. Member FulciLives's Avatar
    There are a ton of guides on this website as well as the doom9 website.
    I suggest you try reading some.
    Also you might want to try Gordian Knot ... most excellent guide for that exists on doom9
    You can't expect us to spoon feed you the entire proceedure. Guides are for that. Forums are for more specific issues like, "What setting in DVD2AVI do I use if I have an interlaced NTSC DVD source?"
    - John "FulciLives" Coleman
  4. I usually use VirtualDubMPEG2 or VirtualDubMod to make Xvid AVI files in Quantization mode (constant quality) with a value of 2 or 3 (as good as 2-pass VBR but in only one pass). No QPel, no GMC, no B VOP's, 224 kpbs MP2 audio.
    their is a little known quirk with the philips dvp642. If the video is jerky try pushing the "system menu" button on the remote 2 times fast. I know but it does work alot of times.
  6. I figured out the problem on my own. I wasn't de-interlacing. Also the resolution was to high.
    Well anyway, it's working now.
    Thanks for all the replies.
  1. Remote for Philips DVP642
    By Melina in forum DVD & Blu-ray Players
    Last Post: 10th Jun 2010, 21:54
  2. Philips DVP642 finally died...
    By Krispy Kritter in forum DVD & Blu-ray Players
    Last Post: 3rd Feb 2009, 13:06
  3. Philips DVP642 DivX subtitles. WORK!!!
    By shrybouski in forum DVD & Blu-ray Players
    Last Post: 7th Aug 2007, 14:06
  4. Output resolution for Philips DVP642
    By cheerful in forum DVD & Blu-ray Players
    Last Post: 2nd Aug 2007, 23:41
  5. Philips DVP642 and DivX 6/Ultra
    Last Post: 2nd Aug 2007, 11:43
