I have 16 DVDs (all SLs) of a TV show of 70 episodes ; most of the DVDs have 4 episodes on them, but one has 10 on it and a few have six on them. The latter groups have all the into/credit etc cut off and are not apparently of lesser quality.
The DVDs have subtitels/sound/ multi-languages tracks/ on them.
I am interested in finding ways of mimicing the 10-episodes/1 Disc (or condolidating 2-to-1, making 8 shows on 1 disc) for the the rest of the shows by cutting off part of the contents, re-working the top menu etc, yet retaining the current features.
I would appreciate suggestions/comments on:
1. Softwares and guides/instructions for this undertaking?
2. Limitations that I should be aware of this task?
3. How can I find out the biprates(?) and/or other info of those discs to be assured of the fair comparison of the video/audio quality?
Thread: Condolidating DVD Dics / files
In reverse order
3. Bitrate Viewer
2. Time and patience
1. IFOEdit, VOBEdit, WMV are some of the tools you might find useful
Unless they are short episodes, then I find it hard to believe you get the same quality from 10 episodes as you from four, simply by cutting a few seconds off then end of each episode.
Wondering any way to lengthen hours of play on a DVD like VHS -- SP (2hr) SP(4hr) EP(6hr) etc? Same length of tape yet yielding more hours of play.
Easy, reduce the bitrate. There are only 2 factors that dictate how much content can fit onto a DVD -- bitrate and duration. Nothing else matters.Originally Posted by LiCal
Of course, the lower the bitrate, the worse the video is going to look. If you go 4 hours or more, you should drop the resolution to Half D1 as well, even 1/4 D1 for anything longer, to help reduce the amount of visible macroblocks.
Like with VHS, the higher the quantity, the lower the quality.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Verbatim Dics?
By pepegot1 in forum MediaReplies: 2Last Post: 7th Dec 2009, 04:43 -
Good Programs that can rip lower quality dics?
By Super Warrior in forum DVD RippingReplies: 13Last Post: 14th Aug 2007, 19:14 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 02:57 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
Statistics
Newest guides
Latest tool updates
New media comments
