I have the following problem: I installed VCDeasy (1.0.5) completely, and then authored the S-VCD. So long, no problem. But I cannot use the integrated support for cdrdao. I cannot activate it, don't ask about ASPI-Drivers, they are installed, no problem, cdrdao works very well on the commandline with my cd-r-drive, the only flaw is it is not fully supported and can only burn with 12x (insted of 24x).
Any ideas why vcdeasy does not activate the built-in support for cdrdao? I have no more clue!
Thread: VCDeasy and CDRDAO
why dont you try the GUI XDuplicator for CDRDao instead of VCDEasy ??????????
do a google serach for the gui
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Due to incompatability the support for CDRDAO was deactivated by default in VCDEasy, you have to turn it on (settings>Enable CDRDAO integration).
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
Statistics
Newest guides
Latest tool updates
New media comments
