VideoHelp.com Forum
  1. What is a nice way of cleaning up a tad bit of noise and a very small amount of blur in the background of my videos captured by my WinTV PVR USB 2 card? The noise is very small kinda like when you have more then one VCR hooked up to a TV. And the blur is just here and there and not more then a second or two.
  2. Member Soopafresh's Avatar
    The blur is probably macro blocks for a few frames. Open the file in VirtualDubMod and look at the parts which blur. If that's what it is, perhaps you can record at a higher bit rate. The other way to fix it is to re-encode with AviSynth and a Deblocking Plugin. Problem with that is you'll lose some quality re-encoding the file.
  1. Replies: 10
    Last Post: 11th Jan 2010, 00:57
  2. how can I blur a small spot in videostudio X2?
    By briansayler in forum Editing
    Last Post: 27th Oct 2009, 03:52
  3. how to blur a small spot in VideoStudio X2
    By briansayler in forum Newbie / General discussions
    Last Post: 26th Oct 2009, 13:50
  4. Blur small section of video
    By zakman in forum Editing
    Last Post: 9th Mar 2009, 18:55
  5. Adjusting amount of light
    By ProducerHarley in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 28th Jan 2009, 18:07
