VideoHelp.com Forum
Results 1 to 10 of 10
    Hi
    Can anyone help me out i have a NTSC mpeg movie and I am trying to convert it to DVD i get a VIDEO_TS folder and when i burn it to DVD the movie plays great no problem accept for the Audio its out of sync by about 1-2 seconds i know its because of the NTSC issue i have the following info on the file:
    MPEG1
    MUXRATE: 1.36MPS
    DURATION:01:11:57s
    SIZE: 480X360, 30FPS(FRAMES PER SECOND) 1.15 MPS
    AUDIO: MPEG 1 LAYER 2
    192KPS 4800HZ
    STEREO
    I have made this mpeg movie into a dvd movie the film rate is good its just the audio if anyone out there that can help me encode the audio properly i would be very gratefull.I must be doing something wrong.
    Matt
  2. Are you authoring this mpeg-1 file to DVD directly, or are you reencoding it to mpeg-2?
    Hi major,
    I'm having the same problem with the audio going out of sync once I've converted and author an avi to dvd. I had this happen with avi's that already have ac3 audio encoded into it. When I tried to drag the video and audio into Sizzle to author it, I get a warning saying the ac3 audio is not 48khz. Any clues?
  4. Did you try to directly use the "Author" tool on your mpg file, without converting it?
    Hi Major
    Yes i am trying to convert the mpeg 1 directly to a DVD movie
    Its just doing my head in.
    Just thought you like to know i drag the movie in the "summary" page then select "target voloume" then "dvd ffmeg" then press "encode"
  7. Try encoding with mp2 audio 224kbps 48000Hz instead of ac3 audio 448kbps (set that in the Audio tab just before pressing the encode button).
    Thanks Major i'll try that i'll let you know how i get on
    I have tried encoding the movie file that you suggested into MP2 it works great thanks Major.
    P.S. just one thing could you still encode into AC3 sound and leave the audio at 224kbps 48000Hz?
  10. Yes, if you use stereo instead of 5:1.
  1. ffmegx won't install mac osx 10.6
    By bloke666 in forum ffmpegX general discussion
    Last Post: 9th Dec 2011, 11:34
  2. Problem with ffmegx
    By jadewolf in forum ffmpegX general discussion
    Last Post: 5th Nov 2009, 09:13
  3. Replies: 2
    Last Post: 5th May 2009, 09:00
  4. I Canīt download mpeg2enc for ffmegX.
    By islandsharp in forum ffmpegX general discussion
    Last Post: 7th Nov 2008, 16:10
  5. ffmegX v0.09w and converting avi videos into avi.ff.avi videos
    By paddymick in forum ffmpegX general discussion
    Last Post: 2nd Nov 2007, 23:10
