A friend of mine recently recorded the birthing of thier child with a sony mini dvd Handycam camcorder, using sony dvd-r mini discs. They watch a little bit at the hospital (it worked fine) and when they get home they tried to watch it and none of the discs worked at all.
Ive tried to rip the discs with dvd decrypter and other various softwares, and no luck. Windows wont reconize anything on the disc either. It wont play on the camcorder either. It worked at one time and I have no idea what they did. As far as I know its screwed. such a shame. The discs look as if there is data burned on them.
If at all possible is there anything that I can do to possibly save these discs?
thanks...
Results 1 to 1 of 1
Thread: mini dvd discs reads no data...
Burning Data Program on DL discs?
By PowerFalcon in forum MediaReplies: 2Last Post: 27th Jul 2011, 07:58 -
Can you copy multiple mini-DVD discs to one standard DVD?
By darkcyber in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 2nd Jan 2011, 09:44 -
Those discs which hold 25 - 50 GB of data.. are they worth it??
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2010, 19:50 -
how to join Mini DV Cam discs onto 1 large DVD-R?
By Debbieengler in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 1st Oct 2009, 15:20 -
Which specifications should I be looking for to play my data discs?
By K_Kat in forum DVD & Blu-ray PlayersReplies: 12Last Post: 5th Jun 2009, 10:53
