VideoHelp.com Forum
  1. I'm getting some conflicting information so I figured I'd settle in the forum's of this truly awesome website.
    I'm about to purchase a Hauppauge WinTV PVR-150 card mainly for TV capture purposes. I'd like to transfer some of what I've got DVR'ed on Comcast's box onto my computer with this card. I don't doubt the card will handle this task well using either S-VHS or composite jacks on both ends. What I'm curious about is the FireWire port on the Comcast box. Has anyone had success transferring from the Comcast box to their computer via FireWire? I would further upgrade my computer if it's possible.
    I'm in the DFW area. I've called Comcast inquiring about this and was told that "90% of the time these ports are not hot, but that I should reference Motorola's website and check there" which I did and of course it doesn't say one way or another. I figured this would be a firmware decision from Comcast's perspective whether certain ports are hot, but I could be wrong.
    This is the box I have.
    http://broadband.motorola.com/consum...ducts/dct6200/
    Any feedback would be appreciated.
  2. Member edDV's Avatar
    The IEEE-1394 port outputs in the D-VHS format if it is supported locally by your cable system. All Comcast channels are encrypted via this port (including DVR playbacks).
    Local DTV channels may be available unencrypted. In April, the FCC ruled that a cable company cannot encrypt these local DTV TS streams. Local stations have the right to encrypt their own stream as they see fit.
    So for encoding your DVR material, you are limited to analog S-Video (recommended) and composite.
  3. edDV,
    Thanks for the reply. All makes sense. S-Video transfer is fine with me.
  4. Member Shocker Milwaukee's Avatar
    @ edDV - Is the same true for the USB ports on the same unit?
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  5. I thought about asking that also, but on my unit it just happens to say "USB 1.1". I don't know if it'd be wiser to try that (If possible) or stick with the S-video port.
    edDV or anyone else - thoughts?
  6. Member edDV's Avatar
    No, as I recall USB is for control. Mine is currenetly non-functional. The Motorola site is the best place to find the full spec for this port. Comcast won't detail their plans.
    From Motorola site:
    USB is v1.1
    "Features such as a smart card interface, DOCSIS and USB are features added for future use by your cable provider and may not be activated at time of purchase. These features were designed for future use and applications that your local cable provider may make available to you in the future."
    Full Spec is here:
    http://broadband.motorola.com/consum...User_Guide.pdf
    Potential USB devices shown are printers, keyboard, mouse, still camera, joystick, computer and hard drive. DVR models have SATA connectors for external DVR HDD.
    You can capture HDTV from a Motorola STB and Comcrap via 1394/Firewire.
    Heres how.
    http://www.avsforum.com/avs-vb/showthread.php?t=403695
    I do it all the time. And no nothing I have captured was DHCP protected or scrambled. HBO,Showtime, Discovery. I do them all.
    I do not have a DVR model. I capture direct to my PC's HDD. I don't think you can transfer things from the DVR.
    BillDoE
  8. Member edDV's Avatar
    Heres how.
    Your mileage will vary locally. My local system is in upgrade and sometimes the digital channels work over IEEE-1394 and sometimes not.
    Currently they are working with the following resolutions and bit rates. Even analog channels produce a TS stream via the motorola box now. How do these compare with your caps?
    Analog - 720x480 8.5Mbps (locally digitized in the DCT-6200)
    Digital - 528x480 15.0Mbps
    HDTV - 1920x1080 25Mbps or 20Mbps
    All interlaced. As reported by CapDVHS.
  1. Is there a way to control a TV set top box over a LAN?
    By True Colors in forum Newbie / General discussions
    Last Post: 20th Oct 2011, 12:00
  2. Replies: 7
    Last Post: 15th Dec 2010, 20:27
  3. setting up dvd / tv / set top box??
    By wundahoss in forum DVD & Blu-ray Recorders
    Last Post: 5th May 2009, 12:48
  4. HD Set Top Box- Teething Issues...
    By bettytron in forum DVB / HDTV
    Last Post: 30th Dec 2008, 02:32
  5. Recording digital tv via a set top box
    By rapattack in forum DVB / HDTV
    Last Post: 16th May 2008, 09:28
